Thread: yamaha moto 200 charging system
    MN250R's Avatar
    MN250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Minnesota
    285
    Hello,
    I been chasing down the charging system on my 85 trimoto atv. All connections look good, i even replaced the recitifier, and a new battery. When i put my voltage tester on the battery it reads like 12.10. When i start it up the numbers dont change at all. When i turn on the headlight it drops to like 11.40. Shouldnt it be up at around 14.00 volts or so when its running? Everything else works great on the bike. Is there any other electrical part that could of failed im missing? is there a charging coil?
    Thanks
    1986 ATC 350X
    1986 ATC Big Red 250ES
    Aug 2004
    Ab Canada
    4,368
    Dose the voltage come back up as the rpm's rise? the charging system wont charge at an idle on most systems, You can do a voltage output test on the coil', you will need the manual for the specific specs tho.
    1985 Tri-Z-
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    No, the volts remain the same even if i give it gas. If the coil was bad would that cause this problem? Wouldn't the machine not run if the coil was bad?
    Thanks
    1986 ATC 350X
    Aug 2004
    Ab Canada
    4,368
    so you pretty much killing battery's ? i would have to look at a schematic of the whole wiring system to give you a competent answer, there's quite a few different systems that work in a few different ways, and no it would run, it would be a AC ign system, possibly a DC lighting ( Cant say without seeing a diagram) some systems use both ac and dc power for lights, along with separate and combined regulator/rectifier systems, your problem could be as simple as a roasted or grounded wire, or a bad electrical part, this is where a manual comes in handy
    1985 Tri-Z-
    Apr 2006
    Crestview, Florida
    2,429
    sounds like the lighting/charging coil
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by MN250R View Post
    Thanks
    There are separate coils for the charging system and the ignition system.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
