I'm going to look at this tomorrow night and hopefully pic it up. I still haven't figured out what model it is.
Heres what I know:
200cc
Seller says its mint
Electric Start, Pull start
No Reverse
Here is the picture that I have of it.
Heres what I know:
200cc
No Reverse
Welcome to the site. I believe that is a Yamaha Tri Moto 200 EK (yamahauler) It should be shaft drive if it is. Will this be your first 3 wheeler?
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
Is there any general maintenance that I should do to this when I pick it up
That yamaha isnt too bad of a machine. I have a 200 chain drive one, and it was very reliable until an old friend threw the chain through the case. They are great for riding wheelies in 3rd or 4th gear down the road, because the motor is mounted further back, and the front is so light. I could do a wheelie for about 1/2 mile but that was a long time ago. They are no means meant for jumping, due to no rear shock and utility front forks, but overall a good machine. good luck, and it does look pretty mint in the pic.
85 Yamaha Tri Z 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
81 ATC 200
Maintenance could be to just check the oil and change if needed. Check the tire pressure, just the basic things, maybe the differential fluid. They are fairly easy to work on. Check it out, see how the motor sounds and runs, and how it drives, and start from there.
85 Yamaha Tri Z 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
81 ATC 200
Yes they do have oil filters.
Yours is probably a 1983, not the same sticker on the gas tank as my 1984. Except the stickers mine is the same. I really like this machine.
1984 Yamaha YTM-225DX![]()
Québec 3-wheeler riders group
I picket it up today for $700, It runs awsome and looks almost mint. Drove it around for a few min in the snow and![]()
Some Issues though,
Weak Brakes
Pull starter wont real up anymore
Charged battery and all I get is a click.
Im heading to the Yahama dealer tommrow morning, to get a plug, oil filter, and see if they can do anything with the pull start.
Edit:
For some reason Im only able to log onto this sit using internet exploder, it wont let me log in under firefox.
