Results 1 to 9 of 9
Thread: 225 DX wont start only backfires
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    Ok guys a buddy of mine bought a 225 DX for 200 bucks. Thing is it won't start we even tried pull starting it, all it does is backfire. We checked the spark it is good, we tried starting fluid didnt work, compression is also good I want to go riding but we can't get this thing to fire and I don't feel like towing him behind my shee the whole way.
    Holland, NY
    635
    did you clean the carb and air filter? If it sat for a while you should drain everything and put new gas and oil in her....good luck
    TRIKES:
    1985 Yamaha YTM 225 DR Special Edition
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    2001 Ski Doo MXZ 600
    1997 Ski Doo MXZ 583
    Nov 2002
    Kirkville, NY
    3,831
    Yeah, clean the carb and air filter. I world also put a new plug in it.
    Timing is fixed on these trikes but it could have jumped a tooth on the cam chain, I would start with the carb, filter and plug though.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    lokisbuddy's Avatar
    michigan, oscoda
    429
    I'm sorry forgot to mention that, we cleaned the carbs new plug and new fuel clean filter. Is it likely that it could have jumped time?
    lokisbuddy's Avatar
    michigan, oscoda
    429
    How do you set the timing on a 225 dx?
    Lewiston, N.Y.
    1,479
    sounds like timing issue if you were to ask me
    May 2007
    PA
    908
    When you said you cleaned the carbs, do you have more than one? Did you clear all the jets and set the needles to the factory settings?
    All things 3 wheel
    Nov 2002
    Kirkville, NY
    3,831
    Check the manual....
    Remove the timing plug on the left side cover (look behind the top of the pull starter). Turn the motor over until the "T" mark on the rotor (looking throught the little hole) lines up with the fixed mark point. I usually take the pull starter off and sping the motor over ccw by hand with the spark plug out. Then take the 2 screws out that hold on the cam sprocket cover on the left side of the motor. When the "T" mark is lined up with the fixed mark the line on the cam sprocket should be lined up with the pointer on the top of the head.
    If the line on the sprocket is off by 180 then sping the motor over once to turn the cam 180.
    Ignition timing (spark) is fixed, check it with a timing light and replace parts as needed if it is off.
    I have the manual scans for this at home and can post them if this isn't clear enough for you.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    lokisbuddy's Avatar
    michigan, oscoda
    429
    that should do it thanks. oh and the s on carbs was habbit from talking on banshee hq lol
