Results 1 to 12 of 12
Thread: blaster with a YZ490 motor stuffed into help needed
    Feb 2003
    33
    hey I'm getting a rolling blaster with out the motor this week and would to stuff a YZ 490 into it for mudding and climbing some hills. has anyone rode one or know of anyone with some parts like a YZ 490 motor,exhaust,carb, air box.?? I built my dream bike it was a 400ex frame with a XR-650L motor stuffed into it. I called it my ( TRX650EX KONG ) so I don't think this will be bad as I did that one for around $800.00 and it was going good until I rode a raptor 660. let me know if you can help. charliekat@oh.rr.com
    my 98 grizzly 4x4 lost spark and need some help with that like a manual, stator, coil, cdi box ,??
    Thanks Chas
    SCEADU's Avatar
    SCEADU is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Atlanta, GA
    330
    Blaster is a lil small for that kind of HP. Make sure you gusset the hell outa the frame because the vibration that the 490 puts out alone will rattle the blaster frame apart.
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    Actually if you go to blasterforum I believe there is a guy there who did that, all he had to do was extend the swinger, gusseting is not neccesary but it is a good idea.
    Oct 2005
    saratoga, ny
    2,819
    i think i know of the one your talking about, was it yellow? that thing was sweet.
    Jul 2006
    well... I might be getting a blaster wensday with a ninja 500 motor wedged into it...... I swear rednecks.....
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    Feb 2003
    33
    I picked up a blaster w/a YZ490 motor already in it. it has a 250r rear swing arm and rear shock. FMF fatty front pipe ,nerf bars ,push bar. new rear tires. it needs a 250r bearing carrier,needle bearings for the swing arm. swing arm pivot bolt,rear brake set up from a 250r. front tires. and a silencer from a 490. I want to get it rolling so I can ride it to see what it's like. let me know if you can help.??
    Chas
    Feb 2003
    33
    I picked up a nice rolling blaster today and was going to put the YZ 490 motor into it. then I looked at the front end and it looks like they put 250r a-arms on it too. so I'll have to use this frame and see how it runs and rides. I will need a rear 250r bearing carrier,needle bearings,rear brake set up.500cc fmf silencer to get this thing off the ground the stance of this blaster is crazy next to the stock roller. I plan on selling it after I take the parts off from it that I need. let me know if you can help.??
    Chas
    Feb 2003
    33
    I measured the out side of the tires on my Monster Blaster 490 and it's 46 inchs.!!! my raptor is 46 1/2 man is this thing going to be crazy. I'll have to get a photo of it. I want to get the carrier on it so it will be a roller.
    Chas
    Apr 2006
    PA
    1,464
    Theres a yz400 blaster on youtube, looks like it RIPS. But I would definitely widen and extend it, or else its going to be nearly impossible to keep down. And that much power in a blaster frame is a just a tad unstable.
    Jul 2006
    you can put a tri-z axle in the rear for more width and then put 400ex hubs on for even more width, I ended up with just at 50 wide on my fiance's old blaster with that setup
    Feb 2003
    33
    please read this as the blaster I have is not set up stock it's like a 250r. I measured the front shocks st-14 1/4 yz-15, rear st-15 yz-17, swingarm st-17 1/2 yz-22,rear tire width st-42 yz-44 wich I plan on getting spacers so they are closer to the front width. wich on the yz-46. so this thing is wide as I want it. when I get the rear carrier and needle bearings I'll see what it is compared to our raptor. it has the 250r swingarm,axle,front a-ams,front/rear shocks. I can't wait to ride it.
