Results 1 to 15 of 18
Thread: Yamaha YFM moto 4 80cc quad
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I bought one of these today(got it for the nephew) I was wondering if anyone knew how to get some information on these quads?? Most important i need to know what year i got,lol. What years interchange? Doesnt say anything on the steering stem. Has white plastics and a red seat,if that helps anyone out?? ANY info would be grateful,,thanks...
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Michigan
    2,718
    WOW no one knows anything about these machines? :?:
    R.I.P Raven
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by 84250r
    What is the vin number? I may be able to help if you do.
    Rittman, Ohio
    6,276
    About 90% of all years YFM80 are interchangeable. MOts chnages were in the motor, or cosmetic. Can you be more specific?
    Michigan
    2,718
    Quote Originally Posted by Howdy
    Howdy there is a number by the shaft,but the numbers are not long enough,,where is the vin number located at?? Bottom of the engine? What years did they make the moto 4 80?
    R.I.P Raven
    Howdy's Avatar
    Celina, Ohio
    10,079
    I don't know for sure where the vin number is on the frame. Also I don't know what all years they were made. hmmmmmm
    Howdy
    Michigan
    2,718
    Howdy,
    Vin number on the motor is 2HX-052146. IF this can help you out. Found no other number up front,steering stem,or ''goose neck'' Please help :oops:
    p.s. Also would you happen to have both rear hubs for this quad? Would like to buy some if you do. I have paypal. Need them with good splines.
    R.I.P Raven
    Michigan
    2,718
    Quote Originally Posted by TimSr
    Tim,
    More specific on what? The way the body looks? Would a picture help you out? I know its not a badger,lol.
    R.I.P Raven
    Rittman, Ohio
    6,276
    By being more specific I was asking what parts you needed to know about interchangeability on. Actually the Moto4, Badger, and Raptor are all YFM80's, and it was all 3 models that I was referring to when I said the were about 90% interchangeable.
    I believe the rear hub you need has a very small spline, and is a 3 bolt? If so, I think all years will fit, but 87-92 has the same bolt pattern (3/70). Im pretty sure 93-03 will fit too but have a (3/90?) bigger bolt pattern. I think TriZinger and Quadzinger hubs also fit and have the same 3/70 bolt pattern.
    Michigan
    2,718
    Heres a pic, Tim ,Howdy.
    R.I.P Raven
    Michigan
    2,718
    Tim,
    On the hubs i have a 4 bolt. But the hubs seem to big for the axle?? It's wobbly. You are right i have very small splines. the guy i bought it form said it needed a whole new axle,, but then when i took a look at it it was the hubs not the axle.
    Heres another pic.
    R.I.P Raven
    Rittman, Ohio
    6,276
    Im 95% certain none of the YFM 80's used a 4 bolt in the rear. Are you sure ist not the YFM100? If not, maybe they stuck YFM100 hubs on it. They were a 4 bolt, but Im not sure on the spline size.
    Michigan
    2,718
    Tim,
    I'm pretty sure its a YFM 80. The hubs seem to big,which causes it to wobble,and tear up the splines on the axle. I did some research and comes to find out that your right none of the YFM'S used 4 bolts. Yet another person with a half a s s job. It will get fixed. Thanks Tim. Just need to find out what year now,lol.
    R.I.P Raven
    Michigan
    2,718
    Any luck on the year Howdy??
    R.I.P Raven
    Howdy's Avatar
    Celina, Ohio
    10,079
    Sorry, Nothing yet. I can't get the number to match anything.
    Howdy
