Results 1 to 15 of 28
Thread: camshaft seized
    Mobile, AL
    74
    camshaft seized
    Okay, so i was rebuiling a 83 200s engine thats just been sitting in my shop. the only thing that seems to be wrong with it is the bushing at the end of the cam is locked onto the cam. So my question is... how is this oiled? How does the oil get from the bottom of the engine to this? just curious because i dont want to press the bushing off and install a new one and then get this problem again.
    heres a pic incase you dont know what im talking about
    Mobile, AL
    74
    i mean does the oil just travel up the chain and sling on the valve and etc? or what?
    Feb 2009
    Rome,NY
    1,046
    has a oil pump
    Mobile, AL
    74
    i know it has a oil pump. but how does it get up there. i dont see any oil galleys
    Sep 2007
    100mi west of Chicago
    3,582
    The bolt hole that needs an o-ring on the cylinder is an oil passage I believe.
    Rob
    Mobile, AL
    74
    so im guessing since mine doesnt have an o ring, no oil up top?
    Sep 2007
    3,582
    Yeah that could be your problem.
    Rob
    Dec 2002
    deer park, texas
    2,336
    nevermind, i was too late
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Mobile, AL
    74
    thanks guys, i think im just gonna put a new cam and bushing in it and then run it till it does it again. atleast now i know how to correct the problem.
    Mobile, AL
    74
    i think i will blow some air through there and make sure it aint clogged.
    Sep 2007
    3,582
    Don't forget the o-ring this time! Probably a 25 cent part. You wouldn't have to get it from the dealer. Any o-ring that size will do.
    Rob
    PA
    3,515
    why did the cam seize in the first place.......replace the oil pump or at least open it up and give it a look over.
    i have forgot the oring on these motors in the past and it ran fine....the dowl pin seals pretty good and the oil realy never touchs the oring.
    that being said i would use one anyway but my point is thats not the reason the head didnt get oil.
    WWW.HREATV.COM
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by mattcruff View Post
    You will be wasting a cam unless you find the problem. To help figure out the problem we need some questions answered.
    1 ) Was the top end rebuilt lately ( low hours since rebuild )?
    2 ) has the right side cover been removed lately 9 Clutch cover )?
    3 ) was the motor ran without oil?
    4 ) Is the black rubber piece in the hole on the Head ( near the bushing for the cam ).
    5 ) Does it have gasket sealant around the cylinder base, head & cylinder, right side cover?
    The reason for these questions is that there is small holes in the way the oil travels to the top end. If one of these are plugged up it will cause the cam to be starved of oil. The black rubber plug also is needed for the oil to get to the topend.
    Howdy
    louisiana
    1,499
    cam
    hey rdlsz i got the same picture here but its a little different.i traced the oil flow in blue so that you could see it better.check it out mattcruff.Click image for larger version.
Name:	84 200X CUT AWAY.1.JPG
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Quote Originally Posted by Howdy View Post
    Howdy
    Howdy, What symptons would you experiance if the rubber piece is not in the head (#4 above)? Currently am experiancing a temporary seizer after 30 minutes of running on a 200S. After about 5 minutes it will turn over and run fine again.
    Thanks In Advance!
