Thread: 85 Big Red starter and tire questions?
    San Antonio, TEXAS
    Just picked up an 85 Big Red in great shape off Craigslist for $500.
    The starter was not working so I took it apart and cleaned it. It does work now most of the time. The question is should I buy a rebuild kit or just buy a starter on ebay. Rebuild kit seems to be about $40, starter on ebay $80-120 with shipping. If anyone has a place to get starters or kits please let me know. Also, what brand of tire and tread design looks good and provides a smooth ride on the Big Red. The tires on it now are hard Carlisles from Wal-Mart and they are just to rough. Thanks.
    86 Honda atc 250sx (sold it)
    84 Suzuki alt 125 (gonna sell it soon)
    85 Kawasaki 180? (gave it away)
    Looking for Heald Super Tryke. (If you know what that is)
    05 Polaris Ranger 4x4
    97 Polaris Sportsman 400L
    85 Big Red
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    im pretty sure the big red uses a 9" rim i use kenda bear claws on my 200 and they run smooth and are also aggressive for snow/mud
    As far as your starter goes, you can take it to a rebuild shop if you want because you can't turn down the armature (unless you have a lathe)
    Many times just a set of brushes does the trick and don't be convinced it's just the starter, make sure the solenoid is making that bag amperage connection. If you run a thick wire right from the battery to the starter positive post and it cranks every time, you could have a solenoid or even the button on your handle bars is known to get corroded and not work consistently.....
    Michigan
    1,144
    You can get OEM tires from Honda
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
