Results 1 to 13 of 13
Thread: May I ask a question about air compressors?
    NE Indiana
    1,067
    I have noticed recently that air compressors with two smaller tanks, instead of the traditional single tank, are become increasingly popular. I was checking into them and the dual tanks have the same gallon capacity (divided up by the two tanks) and all other aspects are the same as compared to the same grade of single tank so my question is, what is the purpose of the dual tanks? Is it an advantage? What are disadvantages?
    NE Indiana
    1,067
    Here is what I mean.
    traditional air compressor
    versus twin stack air compressor
    Those are "quick recovery" where it can maintain a greater pressure and cycle on and off quickly. They usually run nail guns....
    They would definitely not be good for sandblasting but fine for other air tools and there easy to store.....
    NE Indiana
    1,067
    Thanks for that info.
    I need a new air compressor and was wondering what to get. Most of the stuff i do is die grinders, cut off tools, air ratchets stuff like that. I rarely would use it to paint and i have no equipment for sand blasting. So if the twin stack is better for the regular air tools then i think i'll pick one up.
    It's all about the SCFM's....
    Air ratchets and die grinders use a TON of air so make sure you get the right size compressor to run them based on MFG's recommendations.
    NE Indiana
    1,067
    Will do. Thanks
    Sep 2007
    100mi west of Chicago
    3,582
    To run air tools I think you need to look at one of those big upright ones on wheels. I have been tempted to buy one of the little ones for the time being but I am am holding out until I have the space and cash for a big one.
    Rob
    Michigan
    1,144
    If you do much with die grinders and tools like that you need one with a lot more capacity. Look at the label, it usually tells what tools you can use with it.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    I had one of those twin tank compresors in the back of my old work truck, that thing was the biggest POS I've ever used. I ran 1/2,3/8 impacts, die grinders, cut off wheels, etc...that thing just coundnt keep up.
    Just like this one...\/
    TF 07,08,09,10,11,12,13,14!
    Apr 2008
    somerset ma
    1,822
    I have one of those dual "TANK" jobs . The guy I got it from was throwing it away, and didn't even know if it ran or not.. Got it home plugged it in and wa la worked like a charm... The only thing about it is, it doesn't have the volume and capacity that I'd like. But if it's free, it's for me That's the thing, bigger tank, equals more vulume of air
    PA
    3,515
    for running air tools i wouldn't look at anything smaller then 60gal
    WWW.HREATV.COM
    Apr 2004
    Brigham, Québec, Canada
    1,529
    At the farm we have a 40 gal/5 hp air compressor. Seriously I think it is just big enough to use a die grinder. This thing is huge. I'm able to empty the tank with the die grinder in 2 minutes of use. I'm sure I would cry having one of those smaller CH unit. I'll try to post somes pics.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    central mo
    107
    running die grinders, das, and almost any sander 2stage 80 gal tank
    My Trail Pros will out last your Quad
    84 125m tore down
    87 125m
    85 200m redoing top end
