Results 1 to 10 of 10
Thread: spark plugs for my 200s honda
    Nov 2008
    ontario
    1,055
    hey there, just got back from my local canadian tire to buy spark plugs, my bike runs a dr8es stock and the closest thing i found was a dr8ea, i am just sceptical if these are the same plugs? or if it will work. please help me out here guys
    proud owner of a trx300ex quad and an 85 atc 70
    CT
    116
    I run the d8ea which is the same as the dr8ea in my 200, ive had better luck with the d8ea, they seem to last forever! but the dr8ea will work fine.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Mike is correct! A D8EA will work fine.
    You can run a D7EA if you want or need a hotter plug.
    Howdy
    Oct 2008
    NB, Canada
    852
    The Canadian tire by me seems has dr8es spark plug, but I don't use those, I run the champion equivelent.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    with my experience in my 200 i always burn the champions NGK has only failed me once!
    Jul 2004
    Pride, Louisiana
    286
    My 185S fouls out every plug I use except for NGK (Burns a lot of oil).
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    Nov 2008
    ontario
    1,055
    my other ngk plugs lasted 1 ride, thats 2 plugs!!! they were dr8esl, i am running a bit rich. and my electrical may be a bit wack lets hope these hold out today, or else i am switching to champion
    Oct 2008
    NB, Canada
    852
    The problem I seem to have with NGK plugs is that once they foul out, cleaing them won't get them working again, but with Chapions, I can usualy clean them up and they work again. So I run Champions, and they are cheaper.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Nov 2008
    ontario
    1,055
    yeah exactly my expierience, the original champion lasted a year and stopped working these ngk are 2 rides old they show spark but its a weak spark
    Howdy's Avatar
    Celina, Ohio
    10,079
    I use a sand blaster to clean spark plugs and haven't had any problems with fouling right away. In fact for some reason it seems I get more time out of cleaned ones than new ones.
    Howdy
