i was just looking thru the service manual and saw it said B8ES is the proper plug for 85 triz. the one in my machine is br8es which one is the right one?
when in doubt throttle it out
old ride 2002 GSXR 1000
new ride 1985 TRI-Z 250
.070 over - boysen reeds - head redone
2001 dodge ram "off road" (toy hauler)
no one knows?![]()
Not positive on this, but I believe the r in br8es stands for resistor. This plug will work and is actually supposed to be better.
You can use either one..
what is the correct gap then? and what happens when you change the gap bigger or smaller?
Yes, both will work. The "r" does mean it has a resistor in it. The resistor is asupposed to help with engine vibration noise? In the TriZinger it is not needed but doesnt hurt if one is used.
84' Yamaha Tri-zinger 60
85' Honda ATC 70
84' Honda ATC 70
83' Honda ATC 70
78' Honda ATC 70 (140cc lifan)
79' Honda ATC 70
73' Honda ATC 70
85' Honda 200s
83' Honda 200e
85' Honda 250sx
I run the B8ES and never have any problems. Plus they're cheap.
hey guys thanks for the help i piced up the b8es ones ill try them tomm. what about the gap though what should it be and how does gap affect performance?
Head to your local auto parts store!!!!!!!!!!!!!!!!!!!!!!
I run B8ES in all my pingers. Their 3-5 bucks at yamaha, or you can roll down to Oreallys for just over a buck a piece and pick up a couple boxes to last you the year.
I use B8ES in mine.
It's a celebration bitches!!!
