Thread: 85 R axle question
    Carrollton Texas
    76
    85 R axle question
    the axle nut is stuck and need to remove it to install axle bearings but its not coming out or even moving one mm .. the larger nut with the left hand treads is stuck or something, whats the best way to remove them without damaging the axle??
    A.
    Carrollton Texas
    76
    i am thinking of using a torch and heat the living CR@P out of the nut and see if it comes loose.. will the axle be damaged this way???
    because 3 wheels are better than 4
    Internet
    1,251
    try it. stick a big cresent wrench on there with a pipe extension and rev on that sucker till you get a hernia.
    Apr 2008
    NW, IND.
    842
    As long as you don't get it red hot. Penetration oil, heat and time. Sometimes I'll let it set a couple of days. Reheat and try again.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Carrollton Texas
    76
    i drilled a small hole in the large nut and stuffed it with PB blast , will try again tomorrow.. i will try the pipe wrench in the morning if that doesn't work i will have to take the torch to it...
