Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: any luck welding shifter lever?
    Jun 2002
    Mississippi
    2,552
    in my book this is a "it depends" answer.
    if the bike is a beater 200s that you just want to ride then by all means weld the shifter on. either mig or tig and then splash it with water to prevent melting the oil seal. in reality you can buy those engines for $50 off ebay and there is no sense in spending big $$$ on a beater machine. buy a whole motor before you spend the $$$ on a single part and then gaskets.
    if it is a nice machine then fix it right. a 250r shaft can be swapped in 15 minutes if the engine is sitting on the table. it can be dine in frame too.
    so you people need to stop beating on him about it. welding may make sense depending on the machine. inginuity is what keeps these old machines running.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Tilton Newfoundland
    612
    I'd agree with 200x basket but I have seen a couple of beaters with the shifter welded on. From what I've seen there was always a problem with the weld breaking when pounding the gears. This was not issolated incidents. It was different bikes with different welders. Not too big a deal to fix again but woud suck to get stuck in a bog hole or something like snow where the bike may be stuck into, too high a gear or even netural.
    1998 F150 reg cab
    Elan Ski-doo resto mod
    2012 Brute force 650
    98 ranger street truck project
    All my rigs are Loud and proud
    http://bikepics.com/members/mitchell-gosse/
    CENTRAL NY
    1,709
    Quote Originally Posted by oscarmayer View Post
    NO, No NO! this causes the shaft to be weaker and break where you drill it! that's what happened to the guy's I fixed. it stripped, someone used that "set screw" method and then , Oh Snap! Don't drill it and do that. fix it by replaicng parts or as i mentioned welt on a peice of round metal (all thread would work too if needed) (make sure metal is small enough that shifter can slide over it with some slight effort) and grind the back facing side about 1/4 way through and your done!
    Ok.. So you wanna explain to me what the differance is between a small groove horazonilay for a 1/8 set screw so it would be a 1/32 of a groove in the shaft and 1/32 in the shifter or your groove virticly 1/4 the way threw the shaft?
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Feb 2009
    Hanover,Pa 17331
    50
    If you need the 2 parts I have plenty here too,...just do it right,...we ATC'ers need to keep these things alive and repairable in the future,..If you weld it, it'll never be right till you do it the next time right,...If you're ever near me in 17331,..you can have those parts for free........
    Always ready to ride, invite me over, I'll bring the rum!
    Apr 2008
    NW, IND.
    842
    Quote Originally Posted by Jared200x View Post
    Damn, You can't beat that!!+10 "Jared your the Man!"
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Jun 2002
    Mississippi
    2,552
    LOL, i will weld it for free!!!
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    If the splines are gone you mite as well weld it, coz if you've got a welder you'll probably have a grinder to take it back off with, which you wont even have to grind the shaft if you plug weld it from the end. Sure its a quick fix, maybe a bodge, but if it were my machine id weld it on until a new shaft turned up, then replace it as and when. all depends on how you wanna keep the machine & how desperate you are to ride it
    '85 ATC 200x-
    '84 ATC 200s-
    '82 ATC 70-
    '85 ATC 70-(project)
    '82 ATC 70-(project)
    Wife- (project)
    Pa.'s Highest City
    8,058
    Any of you guys ever buy a trike that was cobbled together? what's the first thing you do...
    Curse the former owner for redneck riggin the thing.
    Fix it right... There's people here that are offering you the parts for FREE!
    Jul 2006
    iowa
    451
    In my mind im picturing this trike is a honda 200 series or a similar everyday non-sport trike. In this case, I would weld it. If the shaft sticks a few inches out from the motor, it should be easy to keep the seal from burning. Throw a small soaking wet shop rag around the shaft up close to the motor while you weld it. As long as you get a little bit of penetration with your welder, in my opinion the only downside of this fix is cosmetic looks.
    It doesnt matter how easy or quick some claim you can replace it. In all reality it usually takes a few days to get a part, even with the smoothest of transactions (+the money for the part and a new gasket if needed). Welding is free, and best of all it will be fixed in under 10 minutes. Your machine won't have several days of downtime before you get the part and the time to replace it. If it were me, I would have the old shifter welded onto the shaft and fixed in less time than it took to log on and make this thread.
    And about taking it apart, who doesn't have a grinder of some sort or even a hack saw? Thats just ridiculous. I'm sorry but I really cannot see how this would pose much of a problem at all. If you have enough knoledge to split the cases later on, I really hope that you can figure out how to grind off a weld. In all reality, if this is the every day honda 200s or similar, what are the chances that the bottom end even gets taken apart? What, maybe 1 in every 500 of them will be taken apart and re-assembled for some reason?
    Having said all that, If it is a show bike or a sport trike in good shape I would fix it right as long as I could go without riding it for a few days. FYI, if everyone would just keep that little bolt tight and make sure there was no play in the shifter, NONE of these would ever strip out.
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    Mar 2009
    Alberta
    11
    I've welded mine and haven't regretted it since. Just do a good job. I've tried the bolt methods and have been left with a long walk home on numberous occasions. Welding will last. Yes, it is *gger rigging it, but it's up to you. If you do decide to weld it, make sure that as soon as youre done running the bead that you pour water on the spline where it enters the trans or whatever, otherwise it'll be hard on your seals. Good luck on however you chose to fix it.
    Cars: 2004 Dodge SRT-4 (2.4L Turbo, top speed to date 255 Km/hr. Mods: AGP Wastegate Actuator tuned to 20psi Boost, Turbo Timer, Short Throw Shifter, K&N CAI, Alpine Deck, Full Kicker System, Kenwood Amp, 2 10" Subs)
    2000 Jeep Cherokee Classic (4.0L N/A)
    1991 Dodge Shadow (2.2L N/A)
    Quad: 2003 Bombardier Traxter XT 500cc
    Trike: Honda ATC 250 sx (Mods: K&N Air Filter)
    Mar 2007
    Texas
    5,045
    freaks, the difference is I'm mimicing factory style where your runnign through the center where the strength comes from.
    ________________
    https://www.mikesatvfix.com
    CENTRAL NY
    1,709
    Im not talking about in the center and down threw the top like most people do. Drill from the side not down threw the top. Think of a key way on a fly wheel, same thing just a set screw instead.. A piece of round bar or all thread is the same as a striped shaft no splines its just a little bigger , so its like closing up the shifter more so chances are it going to slip again..
    Im sure it worked in the past for ya im not saying it wouldnt. But in theary all it is, is just a bigger stripped shaft but it dosent have the groove all the way around just on the back side witch would be a plus..
    2001 TRX90
    1984 ATC70 Pit bike
    1984 110 for sale
    Mar 2007
    Texas
    5,045
    all ok, that makes more sense. it coudl work. I jsu did it that way so the shifter coudl stay at stock distance and operate as stock. i wrapped a wet rag arouhnd the shaft near the engine to keep the heat away from the seal.
    ________________
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    My 200 has the shifter welded on, it stripped out like yours did, I just tacked in on the end with a mig welder, if I ever got to take it off all I gotta do is grind the little bit of weld off. It's been like that for the past 3 years.
    TF 07,08,09,10,11,12,13,14!
  15. #30
    Nov 2008
    ontario
    1,055
    my shifter is welded to the shaft on my 200s i didnt do it and can't change it now but its work great for about a year now, the trike is getting a new bottom end any ways
    proud owner of a trx300ex quad and an 85 atc 70
