Thread: Drum brakes?
    Mar 2009
    Earth
    5
    Drum brakes?
    I have a 1986 250sx that is running brakeless. Honestly, I'm not sure if I should bother with brakes because I learned to ride without them. But how hard is it to replace drum brakes or get them back in working order?
    Mar 2008
    EastGreenbush, newyork
    3,494
    very simple, worst part is freeing everything up if they are that bad , if not pads are cheap and a cinch to replace, and cables if you dont want oem are prettycheap to and fairly simple to install. they are worth it even if you only need them once!!
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Quote Originally Posted by dirthead View Post
    So Easy a caveman can do it! Seriously, search the forums for manuals or buy one, get the one for a 250sx and find it in the manual. It's real easy, becareful with all the seals when you take it apart, those seals keep all the water out of the brake assembly and the axle and rear differential. Should take more than an hour or so to do it your first time. The inside of the housing should be clean except for the brake dust- if it's muddy or corroded you probably have a bad seal as well. I think there is about 4 possible seals to go bad on the brake housing. I just had my 86 apart and it was clean, I know I was the first to take it apart!
    Racerxxx
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    braunz200x's Avatar
    braunz200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Toronto
    158
    Quote Originally Posted by aldochina View Post
    well said aldochina
