Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Some help with restoring a 1985 Honda 110 Atc
    Mar 2009
    Utah
    203
    The first question that i will ask is do you have any hints, tips or tricks with solving electrical problems with wiring, devices etc? (I think my trike might have some )
    Second: Any hints, tips or tricks on getting the engine working period?
    Third: Any odd details about the transmission? (I don't really know anything about anything with trikes since this happens to be my first one ) Also, How do the gears shift? (is it push down to go up a gear or push up to go up a gear)
    Fourth and final: Any random hints, tips or tricks on restoring a trike period
    Sincerely,
    Justin aka somekidwithanm4
    May 2008
    Juneau
    605
    to shift nuetral is at the bottom and u go up from there
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    Feb 2008
    Orange County California
    726
    post some pictures so we can see what you are dealing with, then we could go from there. We all know what a 85 110 looks like, but as to the condition of yours, we do not know. As for tips and tricks, patience, and time are the key. What is the problem with the motor? why won't it run?
    Mar 2009
    Utah
    203
    The pics
    Here's the pics you wanted. Don't panick I took it apart it didn't come like that. The only parts missing are the 2 nuts that hold in the exaust manifold, but that's an easy hardware store find. To check if the electrical is work, i just need to try the spark plug trick with the plug out of the engine, holding it in the dark while trying to start the engine. If there's no spark, then there's either a sparkplug problem, or a wire problem.
    The trike itself (the frame if you will)
    The right side of the engine. I now believe the electrical is the main problem due to the fact that i just obtained a wiring diagram from Three wheeler world.
    The wiring up close
    The alternator. The pull start on top of this is very gummed up and i am trying to fix it.
    One of the 2 wires on the top of the alternator came off. I was thinking of attempting to sauder it back on.
    The engine. Note that the block is newer than the rest of the engine. Two owners ago it was replaced.
    Jul 2008
    133
    I'm not seeing any pics.......
    Feb 2008
    726
    you need to check your post, I can see the pictures thru my email but not here
    it may be because of it being face book, try using photobucket, they seem to work for all forums
    Mar 2009
    Utah
    203
    Exclamation
    It's fixed now. look at it again.
    Mar 2009
    Utah
    203
    If you would like i could go and put it all back together again so you could se how it looks like that.
    Nov 2004
    OH.
    2,487
    Deffinately get a manual. The motors in these machines alon with the wiring are pretty simple.
    Mar 2009
    Utah
    203
    I have a wiring diagram, but not a manual. Should i buy it from ebay or get it at a honda store?
    Nov 2004
    OH.
    2,487
    No on the Honda store. They're overpriced.
    Michigan
    1,144
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Mar 2009
    Utah
    203
    They don't got the owners manual, but they've got the shop manual. do you think that'd be okay?
    And also, i've been lookin' through old photos and everything. I've noticed that my three wheeler while the frame may be that of a 85 110, the plastics, fuel tank and many other parts are not the same of that year and are of some difference. I hope this doesn't interfere with my restoration too much.
    Mr.Atc's Avatar
    Mr.Atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    gulliver,mi
    248
    I could sell you a whole 110 threewheeler the same as that one.It just needs a motor rebuild because of lack of compression and you can ride it for 10 minuites and it dies.
    Mar 2009
    Utah
    203
    Lol how much? I guess minus the shipping not unless you want to take the time to calculate that.
