Page 10 of 20 FirstFirst ... 8 9 10 11 12 ... LastLast
Results 136 to 150 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #136
    Sep 2005
    MICHIGAN
    2,027
    Pivot Works swingarm pivot bolt dust seal kits for 1985 KX125 / KX250 / KX500 should work for 1986-87 Tecate
    REFERENCE PART # PWSAK-K07-020
    All Balls probably has one too.
    86 T3
    84 T3
    86 KX250
  2. #137
    alexandros is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Athens Greece
    283
    will the gas tank of the atc 250r will fit to the 86 tecate?
  3. #138
    here
    1,336
    Inexpensive alternative to specialty tool 57001-259 (& 57001-1016) flywheel puller is Performance Tool, Harmonic Balancer Puller part # w151p, at O'Reilly's auto parts. approx. $18.
  4. #139
    OK
    5,450
    1993 KX125 rear master cylinder is a bolt on for the 84-85 Tecate. A longer reservoir hose will need to be used for the reservoir to go in the stock position. The reservoir is smaller and rectangular which will keep your foot from hitting it while kickstarting. The stock rear brake hose will bolt up fine. Here are some pics.
    The 93 KX125 also comes with an aluminum master cylinder guard, I'm going to try to pick one of these up and see if it will fit as well. There are rebuild kits available for this master cylinder too.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
  5. #140
    Apr 2002
    s.w. michigan
    6,498
    While scouring eBay I seen a tecate 87/88 four wheeler shifter and it sure would appear from the pictures to fit up to the 84-86 T-3 machines. Instead of a rounded end, it would be a flatter end.
    If this has already been posted, forgive me.
    http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
  6. #141
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    Quote Originally Posted by jeswinehart View Post
    This is the shifter I have on all my tecates, fits great, looks great, works great.
  7. #142
    OK
    5,450
    Banshee gas caps work on the 84-85 Tecate tank.
    Rides:
    My feedback thread
  8. #143
    Aug 2006
    Arizona
    66
    Yes, A Banshee cab works great on a stock tank. It will not fit a clarks tank.
    Who said that the Banshee gas petcock will not fit with the airbox on the bike? Did they ever notice that the petcock on a Banshee is on the other side of the bike!! So if you use it on a T3 it be facing forward!!
    If you want one that goes strait down then buy the Yamaha 2HR-24500-02
  9. #144
    OK
    5,450
    Quote Originally Posted by Zane View Post
    They were talking about the 86-87 Tecate. Post #99 has a picture.
    Rides:
    My feedback thread
  10. #145
    Aug 2004
    Phoenix
    1,227
    I was the one that originaly gave the tip about the banshee petcock. On the 84-85 you just turn it around so the lever is facing towards the motor. Or if you are handy with machining you can put the brass fitting in the downward or other side outlet and block the orignal side off. There is guy that sometimes pops up on ebay and sells them modified in the downward position, wants like $80 for them though.
    4 Strokes are NOT the wave of the future!
  11. #146
    Aug 2006
    Arizona
    66
    Just so its clear. 84-85 Tecate, a Banshee petcock will work just fine and you do not need to install it backwords. 86-87 it will not work at all with a airbox. Or just buy the Yamaha 2HR-24500-02 petcock with the down spout and it will work with all years.
  12. #147
    Aug 2004
    Phoenix
    1,227
    On the 2HR-24500-02 what model bikes does it come on? Does it also have reserve? Is it the same model as the banshee (2GU-24500-02) with spout pointing down instead?
  13. #148
    OK
    5,450
    Here is a pic, it looks to have reserve
    Quote Originally Posted by scottyms View Post
    Yamaha 2HR-24500-02-00
    petcock for a yfm400 big bear
    list price is 26 bucks, discount prices about 15 bucks
    Fits good... outlet is out the bottom... i think we have a winner!!!
    scotty
    Rides:
    My feedback thread
  14. #149
    Aug 2004
    Phoenix
    1,227
    Yep its the same, those are the ones I will be buying from now on. Night/day better then the stock tecate junk one.
  15. #150
    here
    1,336
    Goodness, in MT the banshee petcock was I think $34 and more than a week out, ouch. Hard to get parts here. "I like that one better too strait down" - The big bear? which one?, so I be sure to get the right one, banshee or big bear glamy?
