Page 2 of 20 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
    Sep 2005
    MICHIGAN
    2,027
    Banshee Petcock for what years of Tecate?
    86 T3
    84 T3
    86 KX250
    Dec 2002
    Orange County, NY
    1,772
    I don't know if this thread contains the post you were referring to in your earlier post but here it goes:
    T3 Parts Interchange
    Thanks for putting out the info for us. I am gearing up to give my T3 some much needed TLC and this stuff is coming in handy for sure. I've read about Banshee, Raptor, 300EX, and 250R rear shocks fitting. Can someone give me some solid info on this as it relates to my 86 T3?
    Thanks.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Sep 2005
    MICHIGAN
    2,027
    Condensed Service Data:
    Kawasaki KXT250
    KAWASAKI
    KXT250
    NOTE: Metric fasteners are used throughout vehicle.
    CONDENSED SERVICE DATA
    KXT250-A1, A2
    MODELS KXT250-B1, B2
    General
    Engine Make Own
    Engine Type Liquid-Cooled;
    Two-Stroke
    Nunnber of Cylinders 1
    Bore 70 mnn
    (2.75 in.) '
    Stroke 64.9 mm
    (2.55 In.)
    Displacement 249 cc
    (15.2 cu. in.)
    Compression Ratio 8.3:1
    Engine Lubrication Fuel: Oil Premix
    Engine Fuel: Oil Ratio:
    Al &A2 30:1
    B1 & B2 20:1
    Engine Oil Recommendation See Text
    Transmission Oil
    Recommendation SAE 10W-30 or 10W-40
    Forward Speeds 5
    Reverse Speeds N/A
    Tire Size-Front:
    A1 & A2 Models 22x11-10
    B1 & B2 Models 23x9-11
    Rear:
    Al & A2 Models 22x11-10
    B1 & B2 Models 20x11-10
    Tire Pressure (cold) —
    Front:
    A1 & A2 Models 41 kPa
    (6psi)
    B1 & B2 Models 35 kPa
    (5psi)
    Rear:
    All Models 28 kPa
    (4psi)
    Dry Weight:
    A1 & A2 Models 130 kg
    (286 lbs.)
    B1 & B2 Models 127 kg
    (279 lbs.)
    Tune-Up
    Engine Idle Speed See Text
    Spark Plug:
    Type NGK B8ES
    Electrode Gap 0.7-0.8 mm
    (0.027-0.031 in.)
    Ignition:
    Type Capacitor Discharge
    Point Gap . Pointless
    Timing:
    A1 & A2 Models 17° BTDC
    @ 6000 rpm
    B1 & B2 Models 13° BTDC
    @ 6000 rpm
    Carburetor:
    Make Mikuni
    Model:
    A1 & A2 Models VM32SS
    B1 & B2 Models VM34SS
    Float Height 15.M9.1 mm
    (0.59-0.75 in.)
    Main Jet:
    A1 & A2 Models #230
    B1 & B2 Models #270
    Pilot Jet:
    A1 & A2 Models #45
    B1 & B2 Models #35
    Jet Needle:
    A1 & A2 Models . 6FJ50
    B1 & B2 Models 6FL56
    Clip Position:
    A1 & A2 Models Fourth Groove From Top
    B1 & B2 Models Third Groove From Top
    Throttle Valve Cutaway:
    A1 & A2 Models 2.5
    B1 & B2 Models 3.0
    Throttle Lever Free
    Play 2-3 mm
    (0.079-0.118 in.)
    Sizes-Clearances
    Reed Petal Stand Open (Max.) 0.2 mm
    (0.008 in.)
    Cylinder Head Distortion
    (Max.) 0.05 mm
    (0.002 in.)
    Cylinder Bore Diameter 70.015-70.030 mm
    (2.7565-2.7571 in.)
    Wear Limit 70.10 mm
    (2.7598 in.)
    Piston-to-Cylinder Wall
    Clearance 0.049-0.059 mm
    (0.0019-0.0023 in.)
    Piston Diameter-
    Measured 5 mm (0.2 in.)
    from Skirt Bottom and
    90° to Pin Bore 69.961-69.976 mm
    (2.7544-2.7549 in.)
    Piston Ring End Gap in
    Standard Bore:
    Top & Second Ring—
    A1 & A2 Models 0.2-0.4 mm
    (0.008-0.016 in.)
    B1 & B2 Models 0.15-0.2 mm
    (0.006-0.008 in.)
    Piston Ring Side
    Clearance:
    Top & Second Ring Semi-keystone
    Connecting Rod Big End
    Side Clearance 0.45-0.55 mm
    (0.018-0.022 in.)
    Maximum Allowable 0.7 mm
    (0.027 in.)
    Radial Clearance 0.037-0.049 mm
    (0.0014-0.0019 in.)
    Maximum Allowable 0.1 mm
    (0.004 in.)
    Crankshaft Runout
    (Max.) 0.1 mm
    (0.004 in.)
    Capacities
    Fuel Tank:
    A1 & A2 Models 13.8 L
    (3.6 gallons)
    B1 & B2 Models 8.5 L
    (2.2 gallons)
    Cooling System:
    Al & A2 Models 1.1 L
    (1.17qt.)
    B1 & B2 Models 1.5 L
    (1.59qt.)
    Transmission Sump:
    A1 & A2 Models 0.7 L
    (0.74 qt.)
    B1 & B2 Models 0.8 L
    (0.85 qt.)
    Tightening Torques
    Front Axle Nut or Screw:
    A1 & A2 Models . 69 N m
    (51 ft.-lbs.)
    B1 & B2 Models 125 Nm
    (94 ft.-lbs.)
    Rear Axle Nut 135 N m
    (100 ft.-lbs.)
    Change Drum Holder
    Screw 23 N m
    (17 ft.-lbs.)
    Clutch Nut 59 N m
    (43 ft.-lbs.)
    Clutch Spring Screws 8.3 Nm
    (74in.-lbs.)
    Cylinder Head:
    6 mm Screws 9.8 N m
    (87in.-lbs.)
    8 mm Nuts-
    Initial 11 N m
    (95in.-lbs.)
    Final 25 N-m
    (18 ft.-lbs.)
    Cylinder Nuts 34 N m
    (25 ft.-lbs.)
    Wheel Retaining Nut:
    A1 & A2 Models 41 N-m
    (30 ft.-lbs.)
    B1 & B2 Models 49 Nm
    (36 ft.-lbs.)
    Standard Fasteners:
    5 mm 3.4-4.9 N-m
    (30-43 in.-lbs.)
    6 mm 5.9-7.8 N-m
    (52-69 in.-lbs.)
    8 mm 14-19 N-m
    (10-13.5 ft.-lbs.)
    10 mm 25-39 N-m
    (19-25 ft.-lbs.)
    12 mm 44-61 N-m
    (33-45 ft.-lbs.)
    14 mm 73-98 N-m
    (54-72 ft.-lbs.)
    16 mm 115-155 N-m
    (83-115 ft.-lbs.)
    18 mm 165-225 N-m
    (125-165 ft.-lbs.)
    20 mm 225-325 N - m
    (165-240 ft.-lbs.)
    All Models
    ENGINE.
    TRANSMISSION. Recommended transmission oil is
    SAE 10W-30 or 10W-40 motor oil with an API classification
    of SE. The manufacturer recommends changing
    transmission oil after every 20 days of operation.
    The transmission sump is filled through filler cap (F—
    Fig. K10-1) opening. Oil level should be maintained at
    middle of sight glass (G). Sump is drained by removing
    plug in underside of sump. Transmission sump capacity
    is 700 mL (23.8 oz.) on all Al and A2 models and 800
    mL (27.2 oz.) on B1 and B2 models. Tighten transmission
    sump drain plug to 20 N-m (14.5 ft.-lbs.).
    86 T3
    84 T3
    86 KX250
    NE Indiana
    1,067
    Great thread.
    I don't have much to offer that hasn't been already mentioned.
    For anyone who may be interested in this, all I can say is for anyone who has an 84/85 that would want to put the front end of an 86/87 on it, it bolts right up. That way the front end is far superior, with better forks, and a taller, skinnier tire for better handling. You will have to make a bracket for the radiator. I see a way to do it using the existing bolts that normally hold the 86 T3 headlight bracket. I will show pics and step by step how I make the bracket when I get it fabbed.
    Oct 2005
    saratoga, ny
    2,819
    arent the steering stem stops different on the two models forks?
    Jun 2002
    Mississippi
    2,552
    i used a 2002 kx125 petcock. bolted right up with NO mods.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Southern MN
    1,875
    Rear hubs from a kawasaki KLT 110 will fit tight, and still uses the stock bolt pattern. (For 84-85 Tecate)
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    NE Indiana
    1,067
    Quote Originally Posted by scooterroo View Post
    They are different only that they are shaped slightly different and look a little different. They both measure approximately 3.5 inches across. Even with the bigger 85 gas tank on, I have full turning radius all the way until the stops meet, and the fork doesn't hit the tank. In fact, with the 86 front on there, the turning radius actually equals a greater radius, because it is skinnier and thus turns farther because of the physics of it.
    So, for all intents and purposes, the stops work just as well, and do their job if the front ends are swapped. I hope that answers your question.
    Jun 2002
    Mississippi
    2,552
    has anyone figured out a replacement for the rear master cylinder on the 86 tecate?
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Dec 2002
    Orange County, NY
    1,772
    Look in the thread I linked to above. I'm 99% sure someone found an easily adapted replacement.
    John
    1986 Monstecate
    1984 ATC125M
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    Quote Originally Posted by nd4speed View Post
    '86-'87, pretty sure it will fit 1'st gen as well.
    Quote Originally Posted by 200x Basket
    I like the Banshee one because I wanted to retain the reserve feature. MX petcocks are on-off.
    Sep 2005
    MICHIGAN
    2,027
    I read a post where a guy put a Banshee rear shock on his LT250R so I believe my assumption about a rear 1985-90 Suzuki LT250R shock working on a Tecate 3 is correct. The shock is like 1.5 inches longer and you could drill the bearing sleeve out to fit the tecate bolt.
    **UPDATE** 6/11/2010
    Another thread where a guy said the banshee shock is direct bolt on for 1985-1990 LT250R
    LT250R shocks are rebuildable and available easily.
    The LT shock is longer than both Banshee and T3 though by 1.5" so maybe Banshee is better fit and even more available, guess it depends on the ride.
    86 T3
    84 T3
    86 KX250
    OK
    5,450
    I hate the look of my 84-85 tecate gas cap, and was looking around the net and found a black billet aluminum one with the vent hose for $29 for a banshee. Checked the cap on the Banshee tank on the tecate tank. Its a perfect fit.
    Needless to say I'm ordering one for my Tecate.
    You can also make an 84 tecates rear shock compression adjustable by using the kx reservoir with the adjuster on it.
    1985 KX125 clutch cable works on a 84-85 Tecate as well. Tried that one at the desert to get my tecate back on the road.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Sep 2006
    N.S. canada
    499
    does the 1985 tecate rear brake bracket fit on the 86 tecate?
    86-tecate
  15. #30
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Anything can fit steve. How goes the tecate? And new pics yet?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
