Page 4 of 20 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 46 to 60 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #46
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by Hoosier_Daddy View Post
    My understanding is the 86/87 KX 250 is the same as the 86/87 KXT 250 so you probably can even buy a 86/87 KX 250 engine for parts and use that for your missing parts. Some of these guys can correct me if I'm wrong.
    If you just want to use the KX 250 engine, the 86/87 KX engine will bolt in your Tecate.
    The 1987 KX250 is NOT the same as the Tecate 1986-87 motor.
    86 T3
    84 T3
    86 KX250
  2. #47
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by ed english View Post
    ok so the 85-86 kx motor motor makes the same power as my t-3 motor?Could i go with a newer year kx?Im looking for a bolt in deal where i dont have to cut up the trike at all.What about electronics?Sorry im new the the kawasaki team.
    You are on your own with a newer motor.
    The KX250 electronics are superior but you can not use a headlight. The electrical systems are generally used as a set.
    You can also bolt in a 1985 KX250 motor but the top end porting and power valve setup is different.
    86 T3
    84 T3
    86 KX250
  3. #48
    Mar 2009
    florida
    4
    iv also herd that the bike motor will rattle my trike apart.Is it really that bad?So the 1986 kx250 uses ALL the same power valve parts?
  4. #49
    Sep 2005
    MICHIGAN
    2,027
    The bike motor is, for all intensive purposes, the SAME. Yes the 1986 KX250 top end and all associated parts are the same.
    86 T3
    84 T3
    86 KX250
  5. #50
    Mar 2009
    florida
    4
    hmmm a buddy says the bike uses a non balanced flywheel amd will cause vibration?anybody?
  6. #51
    Sep 2005
    MICHIGAN
    2,027
    They are all non-counterbalanced cause they are the same motor like I told you already- twice. It would be nice if you went back and deleted some of your posts to clean up this thread and keep it on track. I will add the motor swap info on the first page.
    86 T3
    84 T3
    86 KX250
  7. #52
    Sep 2009
    benson,nc
    8
    yes thanks for all the info my 85 petcock just finished its duty and i have to find another and i know which direction to look just bought a 86 tecate complete needs a good paint job but everthing is there...
  8. #53
    laidout2times is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    SOUTH OF HEAVEN
    180
    My bad. Posting quickly at work. Thought it was the part exchange thread. Not selfish at all Mr. bold type.
  9. #54
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by laidout2times View Post
    Want:
    looking for 86-87 coolant bottle and NOS tires.
    Have:
    Money, BMX parts and bikes, AR15 optics/gear, MMA equip, Muay Thai 1 on 1 training if in philly area.
    Does this look like the CLASSIFIED SECTION for your wants and trades?
    Why do you selfishly feel the need to change the subject and go off topic?
    Delete your post like the guy a few posts above you should have done.
    86 T3
    84 T3
    86 KX250
  10. #55
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Yeah I het when people do that too.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  11. #56
    Apr 2002
    s.w. michigan
    6,498
    Quistion
    Are the 86 and 87 T-3 chain sliders the same ?
    The upper and lower at the front of the swing arm ones.
    john
  12. #57
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    I'm 99.99997 percent sure there was no change in the swinger sliders for '87.
  13. #58
    Sep 2005
    MICHIGAN
    2,027
    chain adjuster for the following models. The OEM number is 33040-4006.
    1984 Kawasaki KLT110
    1984 Kawasaki Tecate
    1985 Kawasaki KLT110
    1985 Kawasaki Tecate
    1986 Kawasaki KLT110
    1986 Kawasaki Tecate
    1987 Kawasaki Mojave 110
    1987 Kawasaki Mojave 110E
    1987 Kawasaki Tecate
    1988 Kawasaki Mojave 110
    1988 Kawasaki Mojave 110E
    86 T3
    84 T3
    86 KX250
  14. #59
    Sep 2005
    MICHIGAN
    2,027
    another thread about the this subject- Tecate 3 parts that fit, swap, interchange
    http://www.3wheelerworldforums.com/s...ad.php?t=69008
    86 T3
    84 T3
    86 KX250
  15. #60
    Nov 2002
    1,838
    Any foot peg springs fit the tecate a1a2? Also anyone know what shock will fit the 83 and 84 kx 250?. Just got more of it done. Still pondering if I should put the tecate motor in it to "try" it out. Im not a 2 wheeler guy so this should be funny. It was all apart when I bought it see pics. And all primed up too. What a mess to sand and scrap.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
