Page 6 of 20 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 76 to 90 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #76
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Yeah. Thinking of doing that to my 83 kx. I love the old look to dirt bikes and trikes.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  2. #77
    Mar 2005
    ma
    988
    Quote Originally Posted by nd4speed View Post
    For 1986 T3 i have:
    Suspension linkage bearing, seal, collar same as swingarm pivot???
    Axle bearings 40x68x15 (same as LT250R) with carrier seals as:
    Left- 40x62x9
    Right- 50x68x7
    swingarm bearings and collars are the same as the upper suspension linkage bearings and collars.
    lt250r axle bearings are cheaper than 86 tecate axle bearings. and there the same parts. kinda odd. lt230, and t4 axle bearings also fit.
    upper shock spherical bearing can be replaced with a much cheaper neeled bearing. bearing number NA4900 UU $5 off ebay. you just have to use the stock bearing spacers and seals. fits perfect. will also fit the 84-85 t3 and the t4's
    lt250r, lt500r swingarm bolts fit the 86 tecates, and should work on the 84-85's. or you can pm yamahondaman for a nice stainless one.
    lt250r master cylinder rebuild kits fit the front and rear master cylinders on the 86 tecate. just get the front for front and rear for rear.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
  3. #78
    Mar 2005
    ma
    988
    i make and in the process of making a few 86 t3 parts.
    chain sliders, made from uhwm, in blue and white.
    aluminum oil caps
    aluminum case savers
    aluminum skids for the swingarm and frame
    rear fender supports
    steel shifters
    aluminum wide grab bars
    stainless fender to seat bolts. little brackets that fit under the seat foam
    replacement rubber grommets for the gas tank mounting
    My Feedback
  4. #79
    Dec 2007
    521
    is the carrier for the 85 the same as the 86 t3?
    A Rental Car is the only true all-terrain vehicle.
    " I actually think it is good that you have clubs where people can go and enjoy riding these things together. It reminds me of how the prisoners on death row have fun waiting for their turn on the electric chair. Fair enough, the trike isn't an electric chair, but it is about as safe and comfortable as one."
    http://www.nps.gov/bicy/
  5. #80
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by bigpimpin View Post
    no...................as for now it is known the carriers fit all swingarms but the matching brake and axle setups must be used with respective carriers.
    86 T3
    84 T3
    86 KX250
  6. #81
    Kentucky
    2,294
    Quote Originally Posted by sblt500r View Post
    aluminum oil caps
    steel shifters
    Then you sir, are..... awesome.
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
  7. #82
    Sep 2005
    MICHIGAN
    2,027
    1986 KX250 has different 4th and 5th gears on the transmission.
    1986 KX250 clutch basket gear has one less tooth while the primary driven gear off the crank has one more tooth.
    1986 KX250 has different shift shaft seal.
    1986 KX250 has 20 tooth primary driven gear off crank/ Tecate has 18.
    Any other 1986 KX and KXT motor differences i should add ?
    86 T3
    84 T3
    86 KX250
  8. #83
    Sep 2005
    MICHIGAN
    2,027
    I was beginning to wonder about fork bushings for all years and for KX250.
    Any one else have any input on fork bushings? (besides below)
    1985 KXT FORK BUSHINGS:
    The oem fork bushings are discontinued through kawasaki. But... since these forks are nearly identical to the 1982-83 Yamaha yz 100, the bushings are exact replacements. Yz units are longer and have a bit more travel, but the components in leg are same. Even the oem yz fork seals and dust caps are better quality imo.......Kyb was the supplier for both machines, so this allows me to rebush all of my 85 kxt forks thanks to Yamaha still carrying replacement wear items.
    86 T3
    84 T3
    86 KX250
  9. #84
    Sep 2005
    MICHIGAN
    2,027
    Rings are 70.00mm. Wiseco ring part number is 2756CD. RIngs fit the following models with Wiseco piston kit number listed:
    Honda 73-77 CR250/MT250 with standard bore with Wiseco piston kit 431PS or 431M07000.
    Kawasaki 98-05 KDX220 with .040 bore with Wiseco piston kit 750P4 or 750M07000.
    Kawasaki 78-86 KX250 standard bore with Wiseco piston kit 439PS or 439M07000.
    Yamaha 76-78 YZ250 standard bore with Wiseco piston kit 234PS or 234M07000.
    Yamaha 80-82 IT/YZ250 standard bore with Wiseco piston kit 452PS or 452M07000.
    Yamaha 83 IT250 with .080 bore with Wiseco piston kit 515P8 or 515M07000.
    Yamaha 85-86 YTZ250 TRI-Z with .080 bore with Wiseco piston kit 515P8 or 515M07000.
    86 T3
    84 T3
    86 KX250
  10. #85
    Nov 2002
    1,838
    Wow!. Thats some good info. Funny how different brands fit different brands.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  11. #86
    Warsaw, IL
    862
    For 1986 T3 i have:
    Fork seals 41x53x10.5 Yamaha part number 775519
    Swingarm bearings TA2030 also found in:
    Mojave
    T4
    KEF300 Lakota
    KX250 86-91
    KX500 83-04
    Left- 40x62x9
    Right- 50x68x7
    I went to the yamaha dealer to order these fork seals. They told me the part number was invalid??
    1969 Trail 70
    1973 ATC 70
    1983 ATC 70
    1986 ATC350X
    1986 ATC250R X 3
    1986 ATC200X
    1987 ATC200X
    2012 Polaris RZR
  12. #87
    Apr 2002
    s.w. michigan
    6,498
    The 86/87 KXT alu swing arm is basically a direct swap out to the 84/85 steel swing arm. You will need to have the shock mount repositioned and welded to center it. You will use all your 84/85 parts on the 86/87 alu swinger IF you don't extend the swinger any longer ~ if you do exstend I used a 85/86 ATC 250R rear brake line since stock for stock the 85/86 250R has a 4 inch longer swing arm then the stock 84/85 T-3.
    Stock for stock the 86/87 swinger is 2 inches longer and around 15 pounds lighter.
    I extended the alu swinger 4 more inches giving me a total of 6 inch over stock length. I also cut out alot of extra alu out of the 86/87 swinger since it was way over built IMO.
    john
    Attached Thumbnails Attached Thumbnails swing arm 2.jpg   swing arm 3.jpg   swing arm 1.jpg
  13. #88
    Sep 2005
    MICHIGAN
    2,027
    Quote Originally Posted by Tyler 54 View Post
    Sorry about that, I had my forks rebuilt by someone else who ordered the seals and i asked him what they were and he said Yamaha and gave me that number. I removed the reference to the number.
    This fork seals (2) fit these models. HONDA 81 CR250R / CR450R . KAWASAKI 82 KX125 , 86-87 KXT250 / 250 TECATE . YAMAHA 84 THRU 96 XT600 , 90-91 XT600E.
    86 T3
    84 T3
    86 KX250
  14. #89
    Warsaw, IL
    862
    Thats fine, I'd just like to get the correct number if possible. My Kaw dealer sucks to say the least. But my honda/Yamaha dealer I get %25 discount. so I'd like to order the yamaha seals for my 86 T-3.
    1969 Trail 70
    1973 ATC 70
    1983 ATC 70
    1986 ATC350X
    1986 ATC250R X 3
    1986 ATC200X
    1987 ATC200X
    2012 Polaris RZR
  15. #90
    alexandros is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Athens Greece
    283
    for 86-87 KXT TECATE:
    FRONT WHEEL:
    BEARINGS: 6203ZZ or 6203ZZCM
    SEAL-OIL: 25X40X8
    REAR AXLE:
    BEARINGS: 6008.2RSR (FAG) or 6008ZZGSR (KOYO) or 6008LU (NTN)
    SEAL-OIL: 50x68x9 you can use also 50x68x10 if you don't find the first one.
    STEERING STEM: BEARINGS:
    LOWER: 32006JRRS ( this bearings include also the seal)
    UPPER: 32005JRRS ( this bearings include also the seal)
    SWINGARM: BEARING: TA2030
    ARM-SUSP,UNI TRAK: BEARING: TA2030
    Fork seals 41x53x10.5 ( If you order them from YAMAHA just ask fork seals for XT600 with part number: 3SP23145-LO they are the same )
    for the bearings just go to a local bearing dealer and order them, thats what i did! You pay less without a loss in the quality!!!
    ( SKF,KOYO, FAG ) for me are top quality brands.
    Attached Thumbnails Attached Thumbnails DSC00053.jpg   DSC00052.jpg   DSC00054.jpg   DSC00056.jpg   DSC00104.jpg
