Also Front Wheel. I heard the 250R fits? I think they are 10in. Do they fit and what size tires and wheels are you guys using.
Thanks
Thanks
3 86 Tecate 3
1 87 tecate 3 (with kx 540 motor)
1 87 tecate 4 (with 330 motor, 250r geometry)
1 83 atc 70
1 Kfx 50
1 kfx 400 ( with 470 parting out bike)
1 78 KZ 1000 ( with 1340 turbo)
1 Aprilia SXV 550 Supermoto
1 01 ZRX 1200 prostreet (sold)
You can buy a 10" wheel from here:
http://www.3wheelerworld.com/showthr...re-we-go-again!!!
The tire size is 22x6x10 I'm getting one, thinking about getting another one too.
Petcocks:
I've got a petcock from an R1 motorcycle in mine(84 tecate). About $8 . has 5/16 lines.
Almost all Petcocks bolt on the same. With the exception of fuel line size and spigot, plenty are available. Wrecked sport bikes off high flow.
I just wanna go fast. If you're not first, you're last!!
Building performance CDIs for the Yamaha Tri-Z, Yamaha Tri-Moto, Kawasaki Tecate, and more.
Plug and play with brand new timing curves.
NastyFastParts.com
You can also find me on Facebook and YouTube under Nasty Fast Parts.
YT175 source coil fits the stator plate ever so slight modification. Maybe 1-2mm griding on the bolt holes to move it inwards and some grinding on the iron part of the coil to shape it correctly.
It's 270-330 ohms, quite a bit higher than the tecates 198-250. With that being said, it should be more potent on the spark. I'm going to give it a shot and let you guys know. I've got 2 spare CDI's, and knowing all the others that fit...
NastyFastParts.com
yt125/175 source coil may not put enough power out. I'm getting spark, but not a really hot spark. Not hot enough to fire. Could be ignition coil. I'll have to take 1 off the blaster to test it out.
EDIT!! I have lost magnetism on a flywheel magnet. No coil sparks well. The yt has done the best so far.. Better than my stock at 192ohms on the source coil.
NastyFastParts.com
I installed a moose case saver for 2003-2004 KX250 on my 1986 T3 so like 1985-2004 KX250 case savers fit all years tecate.
(the bolts included from moose were too long)
Now the moose KX250 chain guard case saver did not look like it would allow anything larger than the 13 tooth counter front sprocket.
The KX500 case saver may be the way to go if you plan to run larger than stock front sprocket.
86 T3
84 T3
86 KX250
The oem shifter spline block can be repaired by buy a new shifter and cutting off its spline block and the OEM spline block and welding the new one on the Tecate shifter.
Dave @ IRL does it and a member did it here:
http://www.3wheelerworld.com/showthr...74#post1320574
I had one done at Delduca welding locally.
86 T3
84 T3
86 KX250
I used the 78-2007 hot rods kit on my 85 tecate crank, worked great.
no spark and stator testing pictures
86 T3
84 T3
86 KX250
1986 Tecate 3 front brake caliper piston:
This Kawasaki 43020-1082 PISTON-COMP-BRAKE is used on these models and components:
1984 KXT250-A1 Tecate FRONT BRAKE ('85 A2)
1984 KXT250-A1 Tecate REAR BRAKE ('85 A2)
1985 KXT250-A2 Tecate FRONT BRAKE ('85 A2)
1985 KXT250-A2 Tecate REAR BRAKE ('85 A2)
1986 KXT250-B1 Tecate FRONT BRAKE
1986 KXT250-B1 Tecate REAR BRAKE
1987 KXT250-B2 Tecate FRONT BRAKE
1984 KL600-A1 KL600 FRONT BRAKE
1985 KL250-D2 KLR250 FRONT BRAKE
1985 KL600-B1 KL600 FRONT BRAKE
1986 KL250-D3 KLR250 FRONT BRAKE
1986 KL600-B2 KL600 FRONT BRAKE
1987 KL250-D4 KLR250 FRONT BRAKE
1987 KL650-A1 KLR650 REAR CALIPER
1988 KL250-D5 KLR250 FRONT BRAKE
1988 KL650-A2 KLR650 REAR CALIPER
1989 KL250-D6 KLR250 FRONT BRAKE
1989 KL650-A3 KLR650 REAR CALIPER
1990 KL250-D7 KLR250 FRONT CALIPER
1990 KL650-A4 KLR650 REAR CALIPER
1990 KL650-B2 Tengai REAR CALIPER
1991 KL250-D8 KLR250 FRONT CALIPER
1991 KL650-A5 KLR650 REAR CALIPER
1991 KL650-B3 Tengai REAR CALIPER
1992 KDX200-E4 KDX200 FRONT CALIPER (KDX200-E4)
1992 KL250-D9 KLR250 FRONT CALIPER
1992 KL650-A6 KLR650 REAR BRAKE
1993 KL250-D10 KLR250 FRONT BRAKE
1993 KL650-A7 KLR650 REAR BRAKE
1994 EX500-D1 Ninja 500 REAR BRAKE
1994 KL250-D11 KLR250 FRONT BRAKE
1994 KL650-A8 KLR650 REAR BRAKE
1995 EX500-D2 Ninja 500 REAR BRAKE
1995 KL250-D12 KLR250 FRONT BRAKE
1995 KL650-A9 KLR650 REAR BRAKE
1996 EX500-D3 Ninja 500 REAR BRAKE
1996 KL250-D13 KLR250 FRONT BRAKE
1996 KL650-A10 KLR650 REAR BRAKE
1997 EX500-D4 Ninja 500R REAR BRAKE
1997 KL250-D14 KLR250 FRONT BRAKE
1997 KL650-A11 KLR650 REAR BRAKE
1998 EX500-D5 Ninja 500R REAR BRAKE
1998 KL250-D15 KLR250 FRONT BRAKE
1998 KL650-A12 KLR650 REAR BRAKE
1999 EX500-D6 Ninja 500R REAR BRAKE
1999 KL250-D16 KLR250 FRONT BRAKE
1999 KL650-A13 KLR650 REAR BRAKE
2000 EX500-D7 Ninja 500R REAR BRAKE
2000 KL250-D17 KLR250 FRONT BRAKE
2000 KL650-A14 KLR650 REAR BRAKE
2001 EX500-D8 Ninja 500R REAR BRAKE
2001 KL250-D18 KLR250 FRONT BRAKE
2001 KL650-A15 KLR650 REAR BRAKE (A15~A17)
2002 EX500-D9 Ninja 500R REAR BRAKE
2002 KL250-D19 KLR250 FRONT BRAKE
2002 KL650-A16 KLR650 REAR BRAKE (A15~A17)
2003 EX500-D10 Ninja 500R REAR BRAKE (D10)
2003 KL250-D20 KLR250 FRONT BRAKE (D20)
2003 KL650-A17 KLR650 REAR BRAKE (A15~A17)
2004 EX500-D11 Ninja 500R REAR BRAKE (D11-D12)
2004 KL250-D21 KLR250 FRONT BRAKE (D21-D22)
2004 KL650-A18 KLR650 REAR BRAKE (A18-A19)
2005 EX500-D12 Ninja 500R REAR BRAKE (D11-D12)
2005 KL250-D22 KLR250 FRONT BRAKE (D21-D22)
2005 KL650-A19 KLR650 REAR BRAKE (A18-A19)
2006 EX500D6F Ninja 500R REAR BRAKE
2006 KL650A6F KLR650 REAR BRAKE
2007 EX500D7F Ninja 500R REAR BRAKE
2007 KL650A7F KLR650 REAR BRAKE
2008 EX500D8F Ninja 500R REAR BRAKE
2009 EX500D9F Ninja 500R REAR BRAKE
43049-1026 PACKING,PISTON SEAL
Description
Purchase this Kawasaki 43049-1026 PACKING,PISTON SEAL --- PACKING,PISTON SEAL
This Kawasaki 43049-1026 PACKING,PISTON SEAL is used on these models and components:
49006-1091 BOOT,PISTON
Description
Purchase this Kawasaki 49006-1091 BOOT,PISTON --- BOOT,PISTON
This Kawasaki 49006-1091 BOOT,PISTON is used on these models and components:
86 T3
84 T3
86 KX250
Front wheel hub parts info 1986 Tecate 3
the axle setup was only used on the 87/86 Tecate
175 175G1020
BOLT-STUD-FINE,10X20
$3.85 $2.40 4
41068 41068-1206
AXLE,FR
$86.01 $86.01 1
481 92033-1040
RING, SNAP,43.5M/M
$4.02 $2.52 1
49030 49030-1071
HUB,FR
$248.59 $248.59 1
601 601B6203ZZ
BEARING-BALL 6203
$16.31 $11.33 2
92027 92027-1951
COLLAR,L=20
$13.02 $9.05 2
92027A 92027-1953
COLLAR,40.2X45.4X129
$29.73 $29.73 1
92049 92049-1110
SEAL-OIL,AG1258A0
$6.61 $4.60 2
86 T3
84 T3
86 KX250
I can confirm 1985 Kawasaki KLR250 KLR Front Caliper Fits using the T3 bracket!
I wonder if the KLR 650 brake parts will fit on the Tecate... If so, there's numerous huge brake upgrades for KLR650's that would make a Tecate front flip from level ground!
LED obsessed
2015 Yamaha FJ-09
The Caliper itself is the same, But the mounting bracket is different.
so unless you can use the T3 mounting brackets on the upgrade I dont know.
