Page 18 of 20 FirstFirst ... 8 16 17 18 19 20 LastLast
Results 256 to 270 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #256
    Sep 2005
    MICHIGAN
    2,027
    The ignition switch for 87 T3 used on:
    1986 KLT185-A1 KLT185 IGNITION SWITCH (KLT185-A2)
    1987 KLF110-A1 Mojave 110 IGNITION SWITCH
    1987 KLT185-A2 KLT185 IGNITION SWITCH (KLT185-A2)
    1987 KSF250-A1 Mojave 250 IGNITION SWITCH
    1987 KXT250-B2 Tecate IGNITION SWITCH
    1988 KSF250-A2 Mojave 250 IGNITION SWITCH
    1989 KSF250-A3 Mojave 250 IGNITION SWITCH
    1990 KSF250-A4 Mojave 250 IGNITION SWITCH
    1991 KSF250-A5 Mojave 250 IGNITION SWITCH
    1992 KSF250-A6 Mojave 250 IGNITION SWITCH
    1993 KSF250-A7 Mojave 250 IGNITION SWITCH
    1994 KSF250-A8 Mojave 250 IGNITION SWITCH
    1995 KSF250-A9 Mojave 250 IGNITION SWITCH
    1996 KSF250-A10 Mojave 250 IGNITION SWITCH
    1997 KSF250-A11 Mojave 250 IGNITION SWITCH
    1998 KSF250-A12 Mojave 250 IGNITION SWITCH
    1999 KSF250-A13 Mojave 250 IGNITION SWITCH
    2000 KSF250-A14 Mojave 250 IGNITION SWITCH
    2001 KSF250-A15 Mojave 250 IGNITION SWITCH
    2002 KSF250-A16 Mojave 250 IGNITION SWITCH
    2003 KSF250-A17 Mojave 250 IGNITION SWITCH
    And boot:
    1987 KLF110-B1 Mojave 110E IGNITION SWITCH
    1987 KLF300-A2 Bayou 300 IGNITION SWITCH
    2004 KSF250-A18 KFX 250 Mojave IGNITION SWITCH
    And DAMPER:
    2003 KVF360-A1 Prairie 360 4X4 CARRIER(S)
    2003 KVF360-B1 Prairie 360 CARRIER(S)
    2003 KVF360-C1 Prairie 360 4X4 Advantage Classic CARRIER(S)
    2004 KVF360-A2 Prairie 360 4X4 CARRIER(S)
    2004 KVF360-B2 Prairie 360 CARRIER(S)
    2004 KVF360-C2 Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2005 KVF360-A3 Prairie 360 4X4 CARRIER(S)
    2005 KVF360-B3 Prairie 360 CARRIER(S)
    2005 KVF360-C3 Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2006 KVF360A6F Prairie 360 4X4 CARRIER(S)
    2006 KVF360B6F Prairie 360 CARRIER(S)
    2006 KVF360C6F Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2007 KVF360A7F Prairie 360 4X4 CARRIER(S)
    2007 KVF360B7F Prairie 360 CARRIER(S)
    2007 KVF360C7F Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2008 KVF360A8F Prairie 360 4X4 CARRIER(S)
    2008 KVF360B8F Prairie 360 CARRIER(S)
    2008 KVF360C8F Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2009 KVF360A9F Prairie 360 4X4 CARRIER(S)
    2009 KVF360B9F Prairie 360 CARRIER(S)
    2009 KVF360C9F Prairie 360 4X4 Hardwoods Green HD CARRIER(S)
    2010 KVF360AAF Prairie 360 4X4 CARRIER(S)
    2010 KVF360CAF Prairie 360 4X4 Realtree APG HD CARRIER(S)
    2011 KVF360ABF Prairie 360 4X4 CARRIER(S)
    2011 KVF360CBF Prairie 360 4X4 Realtree APG HD CARRIER(S)
    2012 KVF360ACF Prairie 360 4X4 CARRIER(S)
    2013 KVF360ADF Prairie 360 4X4 CARRIER(S)
    86 T3
    84 T3
    86 KX250
  2. #257
    Sep 2005
    MICHIGAN
    2,027
    HD hi res professional photos pichtures of 1987 Tecate KXT250B2
    http://www.3wheelerworld.com/showthr...-Studio-Photos
    86 T3
    84 T3
    86 KX250
  3. #258
    Dec 2009
    Oklahoma
    780
    Did anyone notice they put on the masterlink incorrectly?
  4. #259
    Surprise, AZ
    2,428
    Quote Originally Posted by Keith Salyer View Post
    Oops, thats funny.
    It may work for a while if you don't run a chain guide.
  5. #260
    Sep 2005
    MICHIGAN
    2,027
    here's a picture of a LT250r chain slider with custom bracket on top on a T4 not sure if this would work on the 86/87 T3
    86 T3
    84 T3
    86 KX250
  6. #261
    May 2011
    eden,ny
    3,481
    no pic bud
  7. #262
    Sep 2005
    MICHIGAN
    2,027
    Penton Racing makes a ignition system with lighting coil for 1986 Kx500. So if the old school BAJA 1000 KX had a Tecate stator for lights then this should be an expensive option like their PVL without lights? I guess one could ask Penton.
    Here is a great write up on how to set up a PVL with a KX500 head/cylinder cut in half so you can see before top dead center timing (BTDC).
    http://www.oem-cycle.com/forum/viewtopic.php?f=40&t=543
    http://www.kxriders.com/forums/index...ic,8353.0.html
    86 T3
    84 T3
    86 KX250
  8. #263
    Wichita, Kansas
    1,361
    1986 Kx125 flywheel bolts up. Similar to the pvl flywheel. It should work with the pvl stator.
  9. #264
    Sep 2005
    MICHIGAN
    2,027
    i mentioned I saw hillclimber bike builders posting they were trying/running 250 and 125 flywheels/stator,cdi on kx500 motors to get revs/ high rpm.
    I saw 86 KX125 cdi has same wiring layout and wondered if its spark curve would work? Well people ran them on 500s...
    I was hoping someone had the balls to run the 125 cdi with the 250 stator/flywheel as they are much easier to find.
    This post and the one above are all untested theories.
    1986 KAWASAKI KX125 CDI UNIT FITS 84-86 KX125 21119-1195 MAY FIT KX250
    There is no doubt many flywheels will bolt on, it is get stator on and using timing wheel or indicator to set them up is the trick.
    86 T3
    84 T3
    86 KX250
  10. #265
    Wichita, Kansas
    1,361
    The pvl stator matches up, my 2nd tecate had it and the kx125 flywheel.
  11. #266
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Quote Originally Posted by nd4speed View Post
    I'm going order one and try it. I'll let you know
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
  12. #267
    Sep 2005
    MICHIGAN
    2,027
    Brief Highlights: Its always had a stock bore of 71mm. The head was sent to The Racers Toy Store. The cylinder was then recoated and the power valves were cleaned. A Barrnett Dirt Digger clutch kit was installed. New seals, gaskets and bearings were installed. None of which were needed. All remaining available OEM parts were replaced. Wisco piston and rings have been replaced but not needed. Tabs were relocated on the frame to accommodate a new 450 coolant reservoir. Forks were refreshed. Streamline Braking provided front and rear braided brake lines. A 450 rear master brake cylinder replaces the old stock one. A KLX 140 front master cylinder is used for the front stopping power. TRX450 rear hubs +1 were added to the stock axle. Now a 4/110 bolt pattern. The fuel tank has been sealed, coated and painted. Well worth it for the overall finish. Only recent pictures of this T3 have been posted, more are available upon request.
    Some of the parts I've added over the years:
    New carb
    Motion Pro braided throttle cable
    KFX 400 thumb-throttle
    KFX 140 front master cylinder
    ITP blue label rims
    Duro blue TRX 450 +1 rear hubs
    Wiseco piston & rings
    Streamline braided brake lines
    New seat cover
    K&N air filter
    Carbon fiber reeds
    DG exhaust
    OGI grips
    Renthal bars
    Extra JT sprockets 37, 13, 14, 15
    Renthal chain
    ZX6 clutch cable
    Barrnett clutch kit
    Blue silicone cooling lines
    All new fasteners
    All new seals & bearings
    Attached Thumbnails Attached Thumbnails $_57.JPG   $_570.JPG   $_571.JPG   $_572.JPG   $_573.JPG   $_574.JPG
    86 T3
    84 T3
    86 KX250
  13. #268
    Sep 2005
    MICHIGAN
    2,027
    wiring diagram for 86/87 Tecate
    86 T3
    84 T3
    86 KX250
  14. #269
    Sep 2005
    MICHIGAN
    2,027
    1984 1985 Tecate wiring diagram
    86 T3
    84 T3
    86 KX250
  15. #270
    Sep 2005
    MICHIGAN
    2,027
    I saw someone once selling new on / off run switches for 1986 Tecate and it seems they are just off Cannondale atv.
    Here is picture of 2002 CANNONDALE CANNIBAL 440 (SPEED MOTO BLAZE) ENGINE STOP RUN SWITCH BUTTON
    Apparently the on and off are reversed from the Tecate though. This looks to be a good replacement part as it is simply 2 wires to connect , kinda a no brainer. And nice work for whoever was selling them on ebay, dont know why they stopped unless cannondale has discontinued them. Not sure cannondale sells race quads in last ten years.
    There are lots of them on ebay for $13-25
    http://www.ebay.com/sch/i.html?_odkw...witch&_sacat=0
    86 T3
    84 T3
    86 KX250
