Page 20 of 20 FirstFirst ... 10 18 19 20
Results 286 to 291 of 291
Thread: Kxt250 Tecate 3 What Parts Fit Swap Interchange?
  1. #286
    Jul 2016
    Ontario, Canada
    91
    Quote Originally Posted by Queef Chief View Post
    Yep, this is what I run, minus the factory reed stops. Don't forget to add a drop of blue loctite to your reed screws for peace of mind.
    Thanks for the confirmation! Yes loctite is a good plan!
  2. #287
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by emmie357 View Post
    I put an 86 KX250 dog bone on my 85 T3, just needed to use some washers as spacers because the 84/85 dog bones were wider.
    Attachment 211866
    I bought one for my 85. I have not put it on yet because on of the bearings is bad.
    Kawasaki PN 59266-1056
    NLA of course (unless anybody knows a secret source)
    On the plus side, All Balls makes a linkage bearing kit for the 85/86 KX250/500 27-1106.
    I did not buy the kit yet but likely will.
    For putting the KX adjustable dogbone on the 85, I'll probably end up using only the spherical bearings and toss the rest of the kit...
    Looks like most of the kit will work on the 86 T3 as well.
  3. #288
    Mar 2017
    New Jersey
    89
    So can I only use 84-85 rear caliper bracket or will something else work for my axle carrier?
  4. #289
    Mar 2017
    New Jersey
    89
    I see a swap for 86-87 rear master cylinder what can I use for 84-85 rebuild kit? I didn’t see it on the list
  5. #290
    Apr 2019
    Greece
    58
    Hello guys, anyone of you old timers here? Are tecate's alive in 2021 ? I'm deep into restoring a 1986 one! I would like to ask if the gas tank cap from the 1984-1985 tecate fits the 1986-1987 tecate !
  6. #291
    Sep 2005
    MICHIGAN
    2,027
    Bump...I should not have sold all my Tecates...lol
    86 T3
    84 T3
    86 KX250
