KXT250 TECATE 3 WHAT PARTS SWAP INTERCHANGE?
Try to find KX250s that match up to the years of T3 you have. Many parts swap. For 1984/85 Tecate use 1983/84 KX250 motors. For 1986/87 Tecate use 1985-1986 KX250 motors but 1985 cylinder and some internals are different.
Link to Tecate Manuals:
1984/85: http://www.oscarmayer.net/atc/manual...AKI_TECATE.pdf
1986 supplementhttp://thequadconnection.com/Manuals...SUPPLEMENT.pdf
For all years Tecate 3:
Try to find KX250s that match up to the years of T3 you have. Many parts swap. I have stripped an 84 KX and have 2 86 KXs.
Complete KX250 electrical systems 1983-1986 (no lights/ smaller flywheel) can be used and well many more dirt bikes if you have a degree wheel and know how to time everything. Discussed more later in the thread.
T4 Kick start lever and shifter lever.
KX500 FMF expansion chamber o-ring and spring kit
Rear shocks can be made to work: 2001 Raptor, Banshee, 300ex . ( LT250R rear shock is a possibility)
Petcock- Banshee can bolt-on but spigot faces and leaves no clearance for fuel line with the airbox. 2002 kx125 bolts right up.
Oil fill cap plug- KAWASAKI KX 60/65 80/85 1983 - 2009 and KAWASAKI KX 125 / 250 1984 - 2004 and KX500 1986-2004
Tecate 3 swing arms all swap with corresponding linkages meaning the entire rear end cantilever setup.
T3 Intake boots including 1983-1986 KX250 (diameters for carb vary).
T3 Reeds all years and 1983-1998 KX250, KX500 all years, 1987 LT250R/LT500R. Reed cages also same minus Suzuki LTs.
T3 grab bars.
Front sprocket guard / case saver: 1983-2004 KX250, (KDX200 all years?, KX500 ?).
4/156 rear rim like Mojave, 2003 Polaris 500 Predator, and 89/90 Banshee.
Can use many years of KX250 kick start levers but they are longer, spline area is different, and plastic will be in the way of your heel somewhat
Axle Carriers swap for all years.
Stator / flywheel cover are same for all years T3 and 1983-86 KX250.
84-87 T3 and 87-88 T4 flywheels are all the same
Swingarm bolt is same and can use one from LT250R
For 1986/87 Tecate 3:
The 1985 and 1986 KX250 motor is a direct swap into Tecate frame, but the gearing right off the crank is different.
1986 KX: pipe (must mod stinger), intake boot all years KXT, brake levers/ lines, radiators, motor parts (taller gearing off crank-???), cables, intake, chain slides, bearings, rear dog bone longer but adjustable. Stator, flywheel, CDI, and wiring harness must be used as a unit.
1985 KX: same as above except cylinder has different Power Valve (can be made to work).
Stock Front and rear brake discs are the same on 86 T3.
Mojave, Lakota, T4 gas cap
Shifter lever for Honda xr650l 93-04 is a direct fit 86 t3
T-4 tail light.
Lakota tool box- use bracket from Lakota
1983-1986 KX chain slide same as 1986 T3.
4/170 Honda 250R 200x 350x front rim.
Rear wheel hubs: 24 spline 1985-86 LT250R 4/130 and 5/130 1987 LT250R hubs. T-4 (4 on 156mm) and 1986 KLT185 (4 on 4") rear wheel hubs.
The rear hub splines are also the same as These Honda's 70, 90, 11, 125m, 185, 185s, 200, 200e, 200es, 200m, 200s, 200x, and 300ex/400ex.
6008 # rear axle bearings. 6008-2RS, 6008LLU, 6008-RS, 6008LU (depending on one or 2 seals)
1986-2004 KX500 motor. Must mod cross brace to fit spark plug and cap.
For 1984/85 Tecate 3:
Link to Jimmy White Replica manual: http://www.3wheelerworld.com/oldsite...nuals/JWR1.pdf
The 1983 and 1984 KX250 motor is a direct swap into Tecate frame. (This also means the Tecate motor swaps into KX250 frame, sorry, someone needed help with what "swap" means)
1983-1984 KX: motor (taller gearing off crank-??? and trans less robust), front brake levers/lines same as 1986 KX, intake boot all years KXT, rear dog bone longer non-adjustable, Stator, flywheel, CDI, and wiring harness must be used as a unit.
The oem fork bushings are discontinued through kawasaki. But... since these forks are nearly identical to the 1982-83 Yamaha yz 100, the bushings are exact replacements. Yz units are longer and have a bit more travel, but the components in leg are same. Even the oem yz fork seals and dust caps are better quality imo.......Kyb was the supplier for both machines, so this allows me to rebush all of my 85 kxt forks thanks to Yamaha still carrying replacement wear items.
Sprockets for rear 1984/85 Tecates:
JTsprockets.com
JTR 478
Available teeth numbers in: 38, 42, 45, 43
You can also use:
JTR 1478: 30, 34, 36, 38, 40, 42, 43
This sprocket is also available in alloy:
JTA 478: 40, 41, 42, 43, 44, 45, 46, 47
JT
Rear Sprocket
38-tooth
520-Chain
Fits: Polaris
2x4 300 1994-95
2x4 400L 1994-95
4x4 300 1994-95
4x4 400L 1994
Big Boss 250 4x6 1989-92
Big Boss 250 6x6 1991-93
Big Boss 300 6x6 1994
Big Boss 350L 6x6 1993
Big Boss 400L 6x6 1994-97
Big Boss 500 6x6 1998-99
Cyclone 250X 1987
Magnum 425 2x4 1995-98
Magnum 425 4x4 1995-98
Magnum 6x6 1996-97
Scrambler 250 1985-86
Scrambler 400 2x4 2000-02
Scrambler 400 4x4 1995-2002
Scrambler 500 2x4 2001-02
Scrambler 500 4x4 1996-2006
Scrambler 500 4x4 Freedom 2002
Scrambler 500 X 2001
Sport 400L 1994-97
Sportsman 350 4x4 1993
Sportsman 400 4x4 1994-96
Sportsman 500 6x6 2000-04
Trail Blazer 250 1990-2006
Trail Blazer 250 ES 1996-98
Trail Blazer 400 2003
Trail Boss 250 1985-99
Trail Boss 250 2x4 1985-99
Trail Boss 250 4x4 1987-92
Trail Boss 250R/ES 1987-89
Trail Boss 325 2000-03
Trail Boss 330 2003-06
Trail Boss 350L 2x4 1990-92
Trail Boss 350L 4x4 1990-92
Xplorer 250 4x4 2000-02
Xplorer 300 4x4 1996-99
Xplorer 400 4x4 1995-2002
Xpress 300 1996-99
Xpress 400L 1996-97
86-87 Tecate ROCK!
