Results 1 to 11 of 11
Thread: While doing a wheelie bike runs out of gas...
    mgenest is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    NH
    204
    Just like the title says. Everytime I do a long wheelie my bike dies. I think the carb is running out of fuel. Is this a float adjustment? My petcock is at the front of my tank instead of the back like most bikes. I think when I do a wheelie the gas in the tank goes to the back of the tank not allowing any fuel to exit the petcock and starves the carb?
    Sep 2007
    100mi west of Chicago
    3,582
    It sounds like the carb is burning up the gas that's in it and it is not getting replenished since your petcock is at the front.
    Rob
    Columbia
    5,131
    Im thinkin there should be plenty of fuel in the float bowl, unless your doing 1/2 mile wheelies.
    Why dont you try this. Start the bike up, turn the petcock off, and see how far you can make it.
    Mar 2007
    NH
    204
    The wheelies are about 30-40' then I run out. I think I need a bigger carb bowl, lol.
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    i have the same problem with my atc200 and my petcock is in the back =\
    Lancaster, PA
    1,738
    I had this on TRX250X once, it was a clogged vent hose on the carb. Check them out or try loosen the gas cap and see it that is the prob.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Mar 2007
    NH
    204
    Thanks for the tip.
    Jul 2004
    Pride, Louisiana
    286
    And oil if it's a 4 cycle.
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    Jul 2006
    iowa
    451
    it could be flooding out too. a trike should go a lot further than 30-40' on the gas in the bowl. if its doing a wheelie the float may be staying open too long and flooding the motor out. I would check the overflow and carb vent lines and make sure there not plugged and routed correctly
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    Apr 2006
    Crestview, Florida
    2,429
    Adjust the float
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2006
    southern oregon
    2,338
    somethins wrong if you cant get more that 40 feet without starvation... I have wheelied a couple different machines through all the gears before with no fuel issues.. First off I would check the float level and try raising it some to see if the problem goes away... To check if the fuel tank is a problem you might try removing it and using a small bottle instead for testing purposes..
    2-stroke lover
