Results 1 to 15 of 16
Thread: Rear differential lubrication grease
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    Folks
    I went to change the rear end fluid on the 85 big red I am rebuilding (waiting on gasket set from motorheadtoys, he F'd around and mailed it this am when I won it Monday, thought I would be riding this weekend) anyhow, the previous owner put a grease fitting on either side the differential in the axle housing. Pulled the cap off the rear end, nothing but brown grease. I know some newer hondas do this, what do y'all think, try to flush it out with diesel??? or pump a new tube in there and let it come out the fill hole? I know that it takes rearend fluid. maybe this is a great idea, I dunno, I need some feed back though!
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    Pa.'s Highest City
    8,058
    Yikes! your not supposed to use heavy duty bearing grease in a differential like that. your supposed to use 80 or 90w gear oil.
    I'm not sure if it matters.. but I would flush it with kero or dessiel real good and use what the manufacturer recommends.
    Mar 2003
    Australia
    1,919
    I say pull it all apart and flush it out with degreaser and clean everything. Apply grease to seals and axel and put it back togther. Dont use the nipples. The bike wasnt desgined with them, mine is still alive and kicking and has just had regular maitenance. Maitenance is the key. I dont think he means the nipples were on the diff housing Chris? I gather they are on the axel tubes either side of the diff. Check your diff oil level while your at it. Hope this helps.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Pa.'s Highest City
    8,058
    Oh! lol.. I though he meant the former owner filled the rear differntial with bearing grease.
    New Orleans, LA
    201
    yes, the rear diff is full of grease, no oil
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Look on the diff next to the inspection/fill cap, cast into the housing it says what to fill it with I think it's Hypoid 80wt(small letters). At least it is cast into my SX diff, and I think the housings are close to the same(but not exactly) and I wouldn't see why honda would cast the oil recommendations in one diff housing but not the other.
    I'd flush it and put the correct stuff in, the needle bearing at the end of the pinion and the Main pinion bearing needs fluid not grease, there is no gaurentee that its getting up there. Hopefully everything is good and good luck.
    Racerxxx
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    Pa.'s Highest City
    8,058
    I was hoping the guy wasn't that dumb. what a mess you have there. I'd fill it and let it soak overnight in kerosene or deisel fuel.. then flush it several times to get that crap all outta there.
    I didn't think someone could be that dumb. guess I was wrong.
    Baltimore, MD
    6,088
    When my buddys kid raced his old tri zinger when he was young, we used vaseline and changed it every weekend he raced.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Pa.'s Highest City
    8,058
    I highly doubt this guy was racing his bigred every weekend.
    So you saying its ok to leave it in there? I wouldn't! I never heard of such a thing....
    Mar 2008
    EastGreenbush, newyork
    3,494
    WOW, thats a new one, I'm still trying to figure out why? what would be the benifit? I hope everything is ok in there, I say flush it for sure at the least. Probably ought to take it apart and make sure nothing is broken, or to badly worn. Or maybe this yahoo was on to somthing
    New Orleans, LA
    201
    Im not the yahoo, the previous owner was, I just stated that some Honda Rincons have axle grease
    Feb 2008
    NE Indiana
    525
    I wouldn't use diesel or kerosene too long, as it might eat the seals. It probably needs torn apart and cleaned. Bummer.
    smvorndran
    Aug 2007
    Pa
    108
    This is one to add to the list of "What were they thinking"?
    New Orleans, LA
    201
    I might leave it in there
    Mar 2008
    3,494
    Well I wasnt insinuating you were the yahoo, I did realize it was there when you got it, but now after you asking, and everyone telling you to flush it, you still might leave it in!!
