I'm attempting to change the rear bearings on my 125M, the problem i'm having is i'm having a difficult time getting the nut loose that holds the hub on the right side. Whenever i try to break the nut loose, the axle tries to spin and i can get no leverage. What do you guys normally do to prevent the axle from trying to turn while your breaking the hub nuts loose? Also, the rear brake shoes are shot so i have no rear brake so holding the brake down is a no go........
