Results 1 to 10 of 10
Thread: Any of you guys have any advice for easy out for a stripped screw?
    NE Indiana
    1,067
    I have a screw that someone attempted to use an easy out on and the screw head is basically scraped out smooth. I was thinking about drilling a very small hole into the screw shaft and using a small easy out on it.
    Any other, better suggestions? You guys have done pretty much everything so I figured I'd ask first because there may be some better advice.
    It's a small screw so it may be a little fragile.
    kokmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    Sioux Falls SD
    196
    reverse drill bit some times works but if not easy out is only thing i know of. at least if the drill bit doesnt work the hole is already done for the easy out.
    85 Tri-z
    85 Tri-z with Astro Kit
    Apr 2006
    Crestview, Florida
    2,429
    tack weld a nut on it
    Rides
    85 ATC350X
    85 ATC200X
    Jun 2002
    Mississippi
    2,552
    my best advice is to use a reverse drill bit just smaller then then screw. if it comes out great. if not get a heli coil or thread sert and tap it out.
    if you break the ease out off in there you are screwed. the heli coil only takes a few minutes on a 6mm bolt.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Erics350x View Post
    Thats what I would do if its broken off.. If the head is still there file a slot in it and back it out with a screw driver
    2-stroke lover
    Dec 2002
    Orange County, NY
    1,772
    I would say if you are cautious with an EZ out and apply some heat from either a propane or even better, a MAP gas torch you should be able to get it out. Reverse drill bits are great and make an awesome first method of attack since you'll have to drill a hole for the EZ out anyways but heating stuck bolts up is the only way to go. Like someone else said, be careful with that EZ out, it's gonna be ugly if you break it off in there. You won't be totally screwed but you'll probably have to weld a nut to the broken part to get it out at that point for sure.
    EDIT: If the head is there then heat and a pair of channel locks or vice grips should do it.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    May 2007
    Coshocton, Ohio
    1,815
    I have had very good success by very carefully, with a mig welder, piling up very small spotwelds one on top of the other until there is enough material sticking out to get some vice grips onto. Then work it back and forth until it starts to move more freely. The heat from the welds will help free it up so don't wait to use the vice grips on it. If you break an easyout off in it ................. well it ain't very fun then.
    I've even used this method to remove broken off easy outs and drillbits from broken off screws. If it doesn't work the first time don't give up.
    Appalachian American Racing
    the home of
    May 2008
    Juneau
    605
    if there is a head grab it with a vice grip
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    NE Indiana
    1,067
    Great advice guys I knew you wouldn't let me down. Well that said, you're not going to believe this. And you can add this to your list of "can try someday" if you wish. While I was waiting on responses for this thread, I went to the shop, sprayed it with a little PB Blaster, and decided i would try to take the cut off tool on my dremel, because the screw head had nothing left but a smooth crater, and see if I could gently cut into the screw enough to get a good sharp straight screw driver in there that would grab. It was just a "what the hell" idea. I'll tell you what, it worked! The screw backed right out for me! haha. There's another one we can add as a last ditch or maybe first attempt before taking a chance of breaking off an easy out.
    Whatcha think about that? lol. It damn well worked like a charm.
    By the way, i love the welding tips. Never thought about that before.
    Southern MN
    1,875
    Order that grabbit kit off the tv. They say ANY screw or bolt. I dont know how good it works, but might be worth a try??
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
