Hello fellow trike lovers - recently picked up a 1984 cr80 and was hoping someone could offer some advice on problem I have with it.
First gear does not grab when there is load on the bike. When the back tire is off the ground, it seems to work fine (you can't spin the rear tire without spinning the motor). However as soon as load is placed on the bike, it acts like it's still in neutral.
The previous owner said he opened the tranny and the main shaft (it has first gear on it) has been replaced, and all the gears all appear in great shape, no rounding or wear at all. He said the shift fork appears to be in good shape as well, and was not bent. The clutch was also replaced recently.
I plan on opening the tranny and having a look at it for myself, but just wondering if anyone has some thoughts on what else might be the problem. Think there could still be an issue with the clutch?
Any and all help greatly appreciated!!
-Xhum
