Results 1 to 15 of 29
Thread: My 84 250r as of now
    MA
    385
    Well, after a bunch of work and cash I'm nearing actually RIDING the damn thing! Hope I get to though; money has been getting tight and I might have to sell this
    Just had the 20x11x8 ITP Holeshots installed on my Douglas rims. Think the offset is a little wider than stock...
    Front tire is a Carlisle Trail Wolf (23x8x11). Just had that put on and all new front bearings and seals.
    The handlebars are from a Banshee but fit fine. Twist throttle from an 85 250r. Nice new Scott grips and some hand guards finish it up.
    Trike had no lights when I got it... found some and installed them as well as a new Ricky Stator... uh, stator. Still don't work though...
    Plastics are nearly new Meier ones and the seat cover is new too. This was done by the guy before me.
    It has DG slip on now. Looking to get the matching DG pipe too.
    Still have to install the brakes (have everything finally) and the new Boss ATV rear bearing carrier. Have a new red chain to install too as well as a 85 250r carb if I ever get to it.
    What do you guys think? Any idea what I would ask for it if I -was- to sell it?
    Video of it running: http://smg.photobucket.com/albums/v2...nt=Movie-7.flv
    Nov 2008
    Fryburg PA USA
    83
    Id guess...start at 8-900 $ depending on what you got in it and your area? Looks good w new tread and all. Im not a big fan of any thing but factory plastic though, but thats just me.
    86 ATC 350X
    MA
    385
    Does the Maier plastic look any different or just different decals?
    Brad200X's Avatar
    Brad200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Will County, IL
    357
    ^ Different decals, and the color is not a perfect match to Honda OEM.
    Rides I own:
    '85 200X(old smokey)
    '81 ATC250R(Bassani pipe, Wiseco piston, Vesrah rod, and AMS offset rims)
    '84 KXT250 Red(the new money pit!)
    '96 KX125(FMF pipe, Boyesen reeds, One Industries graphic kit, etc.)
    '85 KX125(vintage racer. Technically it was a practice bike)
    '78 DT400(the lone Yamaha)
    Masshole
    2,191
    Bad news, this thing sat for quite some time with water in the crank and cylinder. I enclosed a bunch of pictures to show the extent of the damage. The crank bearings are completely shot, there is almost 3/16'' of vertical play, and there is about 1/8'' of vertical play in the center bearing. You can see the heavy scoring in the cylinder from it being stuck and unstuck. Jug is at 71mm right now. 20 thousands will clean it up. Just the parts alone are going to be about $500 Let me know what you want to do.
    MA
    385
    How long do you think it'll last as is? It DID run
    Joking of course!
    I'll give you a call and we'll figure out what to do. Somehow I KNEW this thing was going to be thrashed inside. Least now I'll have some peace of mind once it's fixed.
    saleen_n_around's Avatar
    saleen_n_around is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Clarksville, TN
    426
    I have a spare jug or two that you might can use with a hone. Don't know anything about the head, but it will be the weekend before I could post any pics...
    Ron Turransky
    1986 250R - Psycho Virgin....
    1985 250R - Venom....
    1984 250R- Resto
    1996 TRX200D - Workin' for a livin'
    Oh, and a Harley...
    MA
    385
    Ok, I'll definately keep you in mind. He thinks this one might survive with a .020 (more) over bore. It's currently at .040 over.
    Masshole
    2,191
    Like aaron said, the jug is useable, just needs a little massaging. I split the cases last night, tranny looks good. Anyone here have a good crank for sale? Im hesitant on having this one rebuilt as it has some minor pitting where the seal rides on the stator side, no sense in using it's going to destroy the seal and suck up a bunch of air. I got your new carrier installed.
    MA
    385
    Cool on the carrier!
    I ordered the HR rod and the full gasket set. I can get a Wiseco set for .060 or .080, just let me know which.
    Masshole
    2,191
    Better hold off on the piston set till i talk to my bore guy, i will drive over there before friday. Your crank has some pitting on one of the shafts, im reluctant to use it as i think it will eat the seal. Post an ad in the classifieds for a rebuildable crank, someone should be able to hook you up for cheap. I would feel better if we put that new rod kit in a better core. If your looking for something else to buy, get a complete seal kit for the motor also. The countershaft seal and kicker seal are leaking. The whole kit can be bought for like 30 bucks. Also you will need the clip that holds the front sprocket on, yours is broken in half. This is a honda only part i think, but prob only like 5-10 bucks.
    MA
    385
    Is your finger right next to a crack on that sleeve too Jeff??
    3rd pic from the bottom, off and below to one side of the reed cage opening.....
    I wonder if you could turn the crank down a MM or 2 yet still allow for the flywheel to bury properly?? I have a seal place that gets me near any seal I want and I do that quite often. The flywheel may not allow for that though......
    Masshole
    2,191
    Ya that seal kit will work just fine. D/C, it does look like a crack, although it isnt its just pitting, stains from the rings being stuck. Im sure if we got creative with the lathe and turned down the crank lobe and pressed on a custom made sleeve that would work, the flywheel wont mind that, but i think it would be easier to get a new used crank, they still seem to be common enough to get one cheaper than go through all the work of rigging this one. Thanks for the input though D/C!!
    MA
    385
    Hmm... I can't find crank bearings (besides the Chinese $20 ones on ebay).
    All Balls doesn't list them (though 'dads' said they might have them if I can get the measurements)
    Does anyone have the numbers or measurements of them?
