Results 1 to 15 of 19
Thread: quick ? on welding my frame
    Apr 2008
    somerset ma
    1,822
    I'm going to be welding my frame up in a little while, do I need to be concerned about any of the electronics? do I need to disconnect anyting before i start welding it up?
    Thanks
    Tank
    Pa.'s Highest City
    8,058
    Depends where your welding the frame I would imagine. if it's real close to any electronics I'd move them outta the way..
    if not ground it out and weld away my trike riding freind.
    I took my wheeler to work.. drove it in the back door. welded up the swinger and rode it back out. no problems.
    Tionesta, PA
    5,747
    It is a good practice to unplug the CDI box.
    Apr 2008
    somerset ma
    1,822
    Here is the area in question,, typical 85 frame crack
    Pa.'s Highest City
    8,058
    Good point Timmy. Ya never can be too sure what all that current is going to do. But I had no problems.
    Feb 2009
    Philadelphia, Pennsylvania, United States
    53
    I weld everyday, hook it up and go...... It will be fine
    1985 250SX..........Love it!
    1984 Atc 70. In the repair and build phase....
    2002 Polaris Trailblazer 2x4 (wifes ride)
    Past Rides
    1985 200X
    PA
    3,515
    Quote Originally Posted by Dave's1985200X View Post
    99.9% of the time you would be right.
    one time i seen a stainless brake line act like a fuse and melt, we weren't even welding near it.
    WWW.HREATV.COM
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Just to be safe I would disconnect the CDI. I've seen electronics get fried before from someone welding and not disconnecting stuff.
    TF 07,08,09,10,11,12,13,14!
    Apr 2008
    somerset ma
    1,822
    Thanks for all the the help guys, The weld came out good, I'll post some pics. up later
    Tank
    Jackson MI
    1,688
    When welding on anything with electrical parts, I suggest you hook the ground as close to the weld as possable.
    Swigin, sounds like the stainless brake line carried the ground. I had the same problem on a truck, It had a bad ground from the engine to the frame. I hooked the jumper cables up, had a co-worker spin the engine over and watched the power steering hose smoke. It was working as the ground. I'm not saying unhooking the CDI Is a bad Idea, because It's better to be safe.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Apr 2008
    somerset ma
    1,822
    I also took all of your advice and unhooked the CDI box, I didn't bother to try to grind down the weld to make it look pretty,, The frame is getting trashed as soon as I start the frame swap anyways..
    before
    after
    after, after
    Like I said, it doesn't need to be pretty
    Nope it doesn't need to be pretty but - EEEEW - I thought that guy could weld like nobody's buisness??
    That taint no DC weld!!
    Oh well, it'll be just fine for now.......................
    illinois
    743
    whet rod did you use? i believe the frames are chromoly
    thats why it looks so poor prolly
    when you weld - you want to keep the ground as close as possible to your work, theres always a chance of the current to flow through all the bearings in it!
    this could spot weld them ect...
    ALWAYS CHOOSE THE CORRECT ROD,OR WIRE
    keep the shocks from getting hot from the heat
    electronics can be affected as well
    It's an 85 frame so it's plain steel.
    It just looks like crap
    Again, it will serve the purpose, but a GOOD total swap of all the parts to another frame can take quite a while. Swaps are a great time to address and fix everything, rebuild forks, allballls bearings etc etc etc.
    I would have put a nice brace on the backside just so I'd know it would last and give Roy time to swap it over. BUT, I asked him for a 30pack so I can understand why he let Harry Hacker do it J/K sorry, I couldn't resist
    Good point about the bearings though as I've seen that happen myself :
    Apr 2008
    somerset ma
    1,822
    in his deffense, he's welding on top of old bird shite weld, very little prep to clean old rusty frame.. believe me, this is better than it has to be.. DC you need to come over my house to see how good this guy can weld
