yamaha tri moto 125
82 psi seems WAY too low, and that is why it wont run. In my opinion you need at least 115 psi or greater. There were no yamaha tri moto 125 m's. The earlier tri motos from 80-81 were known as the G (1980) and H (1981). There are a lot of differences. I see the piston is listed different, the rear axle is different and smaller on the 80-81 and use a smaller axle nut, the frames are different as is the air box, carburetor, reed cage is much bigger in the 82-85 models. The later models 82-85 are known as the J (82) K (83) L (84) and N (85). They skipped the I and the M for some reason. Make sure you got the right model and year before ordering parts. Basically, there are two different styles of 125. Good Luck!!
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
