Thread: wanting to know a price on a frame and swingarm
    i am wanting to know what a good price would be for a good 1986 250sx frame and swingarm. comes with frame, swingarm (minus final drive), rear brakes, axle.
    Thanks
    James
    bump
    bump
    Depends how nice it is. The 86 has the same style as the 87 rear and let me tell you - parts to fit the 87 diff and brake set up are not nearly as available as the 85 style and more $$$$ so it may be a pain in the ass - I never see 86 final drives. Remember that your 85 stuff you have should bolt right on to the 86 frame so no sweat. Frame and swing and axle, brakes etc - well worth a couple hundred bucks$ but if the swingarm bearings + seals are on there way they are 100$ from Honda so???? And you can't swap those very easy at all. Not sure what happened to your frame etc. but, I have an 86 frame I can install brand new swingarm bearings in - if your interested in just a frame - same as 85 though - just has an 86 sticker! I can shoot a pic.
    nothing happend
    i just want the 86 frame and swing b/c of the wider rear end athe better brake assembly.
    Re: nothing happend
    Quote Originally Posted by 250sxRacer
    Wider rearend?? Same width - the swingarm is just shaped sifferently with less braces and supports.
    no
    the 86 axle is longer
