I am going shopping tomorrow for oils for my 86 250r.
What is a great 2 stroke mixing oil, and at what ratio.
Also, what should I use for the tranny, also, any idea how much it holds?
Thanks
Thanks
Do a search, got to be a dozzen threads on this and even more opinions.
82 200e
85 250es
86 250r
Trike fest 08,09,10,11,12,13,15 and counting
Coal creek 09,10
Invasion 2011 , Trikes ridden in 13 diff states and counting
BELLRAY GEAR SAVER IN THE TRANS
maxima 927 32:1 for mix
or klotzh super technaplate 32:1
both are great
sometimes I threw in bellray MC1 at 50:1
I run HP-2 oil at 48-1, and HP trans oil In the red jug. You will put about 3/4 of the quart In the trans. In the clutch side cover Is a bolt with a 10mm head, above It It says oil check. Pull that bolt out, pour the oil In until It leaks out the hole. Then tip the bike over a bit to let the oil run to the oposite side. Let It sit back on 3 wheels, then fill It until oil comes out of the check hole again, put the bolt back In and your go to go.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
I run HP-2 in the pre-mix. One bottle to 5 gallons gives you 40:1. That makes it easy and I like easy. I use Honda manual trans oil that I got from when I worked at the Acura dealer in the gearbox.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
