Results 1 to 11 of 11
Thread: has anyone tool dipped a tecate intake?
    Jun 2002
    Mississippi
    2,552
    Question has anyone tool dipped a tecate intake?
    the intake on my tecate is cracked up like most of them. i bought some tool dip today and plan to try and coat it. i plan to clean and bead blast it before i coat it. has anyone tried this? did it work?
    i also bought a kx rad valve. it is angled wrong but i hop to cut it off and have it welded were i want it. i hope it does not warp the reed area.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    NE Indiana
    1,067
    Yes, and once i dipped it, I actually put a second coat on. Works like a charm.
    Sep 2008
    Northwest Indiana
    550
    Been there and had somebody else do it for me......lol! They turn out next to brand new!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    the tecate kid's Avatar
    the tecate kid is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2007
    Cincinnati, OHIO
    406
    I've done it two ways. Once with they spray coating and once I used the dip, but brushed it on. The dip is way better. Its much thicker. Once it dried, it looked like a brand new part. Works perfect, and its been on for 2 years now.
    Been There...Dug That.
    Bartlett TN
    3,083
    Hey Chris, I got some yellow brand new in the can I will bring you if you want hehe. That sounds like a good idea, but I know with that stuff you have to be very patient when doing it.
    86-87 Tecate ROCK!
    Apr 2003
    Central New York
    1,864
    Tool Dip
    Ok it seems we all have the same problem with our Tecate Intakes. Mine was new less than 10 years ago and is now cracked.
    What is this tool dip and where do you get it. Is there a better brand and way of doing it? Mine will be done soon before I get a nasty air leak. Looks like I need to do the head on her so I may as well get all the little things I see done and finished before the summer. Thx
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Bartlett TN
    3,083
    Its called Plasti Dip by Performix and you can get it at most auto stores and maybe Walmarts. They have black, blue, red, yellow, white, and clear.
    86-87 Tecate ROCK!
    Sep 2005
    MICHIGAN
    2,027
    I used Rustoleum Grip & Guard. You could also probably get it at a Hardware store. More than one coat is recommended right in the instructions.
    86 T3
    84 T3
    86 KX250
    I used the stuff on a banshee 2 into 1 intake...worked good but it took many layers to get the diped thickness
    Apr 2003
    Central New York
    1,864
    dippin or painting exterior?
    Do you dip it all in or just do the exterior. Would think the interior would get smaller and that wouldnt be good? Or does it not matter.
    84-85 Custom Tecate
    Bartlett TN
    3,083
    You can put masking tape over the carb hole and over lay it just a tad as that is where the carb mounts anyway. Then dip it in the solution. I used a plastic bowl to keep from ruining any dishes, as my wife would kill me HAHA.
    86-87 Tecate ROCK!
