I have a 1984 200s that has started leaking oil inside the recoil somewhere. Does anyone know what could cause this or how to go about fixing the problem?
Thanks in advance for any help![]()
There is a seal behind the rotor which seals the case to the crank shaft. You can drain the oil, tank the pullstarter and rotor off then unbolt the cover so you can take the seal off the cover.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
thanks thefox. Does anyone know if I need any special tool to change the seal?
you should be able to get it out of there with a small pick of some sort uve used a paper clip on counter shaft seals and i belive its about the same thing
My rides
MINT 1986 bw 200
I changed that seal on my Honda 200e motor, and I didn't have to drain the oil.
Rides:
1985 250sx
1982 ATC185s
1984 200es
Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
"Wear Limits Are Just A Suggestion"
The 200e has a different style rotor so you wouldn't have had to pull it either.
Charles, you will have to pull the rotor because your cover is behind it. You can use a 2 jaw puller and pull on the recoil basket but if the rotor is really on there you could bend the basket. There is a special puller that threads inside the rotor, they are about $15.
Once the cover is off you can use a pick or screwdriver to remove the seal.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
