Almost all the Honda hubs run 4-170, You won't find a bolt on 4-130 hub that centers itself and works with your caliper.
You are wanting the wrong rim..........
AND - as far as being "interchangable" - Maybe not... I've checked 350X, 200X and 250R hubs and almost every hub has a different relationship between the rotor mount to the rim mount distance. Not much, but they are different.
Any of the hubs can be made to work but I believe your issue here is a front rim you really want......
That WON'T work
