First off
to the boards!
I just thought you might like this info:
smvorndran (one of the guys on the boards wrote this), I'm not taking any credit for this, I just saved it for future refrence for my 250SX and I thought I share it with you. Also if you search the boards other guys have put complete 200X front ends on as well, this way you get the narrower sport front tire rather than the fatty.
"Quote from smvorndran"
"I used the 250SX triples, 200X forks, 250SX fender, 250SX headlight, 250SX front axle, 200X front wheel & brake system. To do the conversion, like Dirtcrasher said, you need to add spacers on the outside of the current 200X spacers on the 250SX axle, and add spacers between the forks and caliper mount plate. My axle spacers were .790" Outside diameter, 19/32" Inside diameter, and .790" long. You need 2, one for each side. The brake plate that bolts to the forks needs spaced as well. Those spacers were 5/8" Outside diameter, 21/64" Inside Diameter, and .790" long. You need two of those as well.
You'll also need 2 new M8x1.25 x 65mm flange head bolts to bolt the plate back on. My hardware store only had 70mm long bolts for $1.80 a piece. I ground the length down a little, so the bolts just stick thru the plate about a 1/16th of an inch. It's going to be an awesome setup!!! Just a note, I also added 1.25" long aluminum spacers on top of the springs to take out the sag of the forks on the heavier 250SX."
If you've got a spare set of spacers sitting around I can turn down on a lathe, I'll hook you up. It took more time to measure things up correctly than it did to bolt it together. Now that I have the measurements, it's an easy conversion. You have to use the 200X stock spacers towards the inside of each side, then add modified SX spacers to make up the difference.
Racerxxx
1985 Honda 125M (My first Trike--Still have it)
1986 Honda 250SX
1981 Honda 110
1982 Honda 110
1986 Yamaha YFM80 (Sons quad)
Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
1987 CR-80, 70's vintage XR75, RM 370
