Results 1 to 12 of 12
Thread: Tri-Zinger Shaft/Rear Gear Lube
    Feb 2009
    Oklahoma
    41
    I have a '85 Tri-Zinger 60 and I am just put a piston in and was changing the crankcase oil and wanted to change the Rear Gear Lube but didn't see a filler point or drain. Does the crankcase lube go throught the driveshaft tube and lube the rear gears?
    Also, anyone know if a regular tether kill "key" will fit in the trizinger tether switch? Looking to get that going also on this.
    OK
    5,450
    I'm in for the answer to this as well.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Sep 2006
    Northwest Indiana
    1,893
    It's not hypoid gear oil, and it's not grease either. It comes in a tube and is availiable at the Yamahe dealer and is called Grizzlly grease. It's has a consistency like jelly. It's used in the cvt of the yamaha grizzly atv's, and others. The axle assembly has to be removed and cleaned in a pressure type solvent tank with ring and pinion exposed. Then squeeze contents into housing. It's the correct lubricant for the tri-zinger.
    OK
    5,450
    Thanks, it is much appreciated.
    Rides:
    My feedback thread
    Feb 2009
    Oklahoma
    41
    How often should this be serviced?
    Thanks
    Mar 2017
    Chico CA
    119
    Necro bump.
    Anyone do this service? Any tips?
    Aug 2016
    East of Worcester ma
    1,353
    Quinc, I’ve done it a few yrs ago, not a hard job just be super careful of the splined/tab lock washer. It took me yrs to find a couple nos ones. (For next time) haven’t seen any since.
    Shep
    Mar 2017
    Chico CA
    119
    Shep
    Good to know!
    Anyway to check if it needs to be greased without taking it apart?
    Aug 2016
    1,353
    Nope/ after 30+ years I’m sure It does. If you do it at least you’ll know it’s done and possibly good for another 30.... I had mine apart to replace the axle some numb nut welded the hubs on (threw that one in the trash).
    Shep
    N.E. Ohio
    2,005
    When you get there they call for a reversed style tool. Use a lug nut from a Warrior/Tri-Z the bolt itself is only hand tight. The lip on the lug has a flange to grip too. When I get home I’ll try and take a pic.
    N.E. Ohio
    2,005
    Here is what I’m talking about.Click image for larger version.
ID:	261693 you can use a lug nut off a Warrior to make it work. Sorry for pic rotation, it’s called a final drive shaft bearing retainer.
    Apr 2012
    USA
    4,133
    For the kill switch/tether question. You can use a tether, just need to match up the wiring to the OEM harness. Should be Black (ground) and Black/Red for the two wires. You need a normally open switch (when the tether is off, it should be shorting the two wires). There's two points to wire it in, either at the ignition control switch, or the emergency engine stop switch. Don't know too much about the model so not sure where they are located exactly, but here's the wire diagram for reference.
    This assumes you use the stock ignition control switch for the run/start, the tether would only be for killing the engine.
