Page 11 of 16 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 151 to 165 of 240
Thread: Tank's 1985 350X build is FINALLY all done! ;-)
  1. #151
    Oct 2007
    Grosse Tete, LA
    3,440
    with the oil thing backwards, does it completely starve for oil blocking all flow? or does it just limit the flow?
  2. #152
    I could be completely wrong, but I gave my thoughts on this yesterday.
    I wondered if the light spring was there so that if the filter were to get plugged, the oil could bypass the plugged filter??
    Like I said, it's just a guess and I may be blowing smoke (like all Roy's motors J/K) I'd have to take a better look at the install and which way the oil feeds thru to understand it.
    I just can't see any other reason for that spring? Otherwise I'd imagine both sides of the oil filter would have rubber seals that sandwiched between the cover and the engine.......
    I never get anywhere from "not thinking"
  3. #153
    Apr 2008
    somerset ma
    1,822
    Quote Originally Posted by jeffatc250r View Post
    So any update on this? Did you pop the top off to see how things look?
    Na Jeff, not going to take the top off just yet, Haven't had time to work on it, been a busy week at work. Tonight (trhursdays) we race RC cars. I'm going to get it finished tomorrow and hope for the best (not to worried about it)
  4. #154
    Masshole
    2,191
    Atleast he will prob make things right with you if its dicked up, 2600 feedback at 100% positive is reassuring.
  5. #155
    Apr 2008
    somerset ma
    1,822
    Well Guys, I just finished putting it back together around 8:00 EST.. It started up on the 3rd kick and ran just fine I let it run for a little while, off and on the throttle trying to listen to the engine for any foreign noises(esp, the top end).. I'll tell ya guys, it doesn't sound bad at all, in fact, it sounds pretty damn good to me I took it for a little rip around my field and went through all the gears and it feels tight, with plenty of power It even starts back up nice and easy after riding it for a few minutes... I think I'm going to luck out here after all But you never know
  6. #156
    ^ Oh sure, it sounds good NOW. But wait until the oil filter that was probably in right and "fixed" and put in backwards by you - starves the topend with oil
    Read your manual, double check your chit and your good
    I've got chit to fix both Sat and Sun if you want to bring it by, rip the track and do a compression test. I'd like to hear it anyhow.........
    I'll give you a call in the AM or call me and MAKE SURE I ANSWER or RESPOND!!
    Hopefully this is like my 86 motor that I can't kill Well, I guess I could run it low on oil or install the filter backwards but that wouldn't be any fun
  7. #157
    Apr 2008
    somerset ma
    1,822
    I actually double checked it before I put any oil in it, I pulled the cover off and low and behold it said right on the filter, (TOWARDS COVER) Just for craps and giggles, I checked the filter that I took out of it and there wasn't any markings on it at all!.. I'll bring it with me DC to show ya, I'll call you around noon time
  8. #158
    Good to hear Roy-boy. Good luck with it.
    Apr 2008
    somerset ma
    1,822
    Just got back from DC's house. we did a compression test on it and it came up 192psi DC thinks I did really good on this engine which is very reassuring... Only thing is it needs a clutch! It slips a bit, and we couldn't adjust it out.... Oh well
  10. #160
    Aug 2005
    Lockport, NY
    2,395
    Any NOS motor or near NOS motor will always need a clutch. You cant just buy a new engine and run it. You should always crack it open an look at that stuff.
  11. #161
    Oct 2007
    Grosse Tete, LA
    3,440
    yep...clutch fibers are gonna be crap. clutch springs are gonna be weak. Valve springs are gonna be weak. the list just keeps going.
    That's why i hate those adds that say..."ready to run"...uh...no.
  12. #162
    Apr 2008
    somerset ma
    1,822
    Hey DC, just got an email from that site that I ordered the clutch cable from, and they told me it was discontinued WTF!!. Looks like I need some other options
  13. #163
    Who was it? Biker Douche??
    Look for Motion Pro, or get MY CABLE OFF YOUR 350X!!!!!!!!!!!!!
    Your clutch should be here Thursday or Friday and hopefully we'll get it done right away - ok??
    DC out.............
  14. #164
    Apr 2008
    somerset ma
    1,822
    Yea, it was, biker "douche" bandit. I figured I'd get ya an OEM... I'll look into the Motion Pro one.... I'm on vacation all this week, so any time after it comes in is ok with me
  15. #165
    Apr 2008
    somerset ma
    1,822
    Hey DC is the part # for that clutch cable 02-0214,, through motion pro???
