Results 1 to 14 of 14
Thread: Fixing the dent in my gas tank. Advice?
    NE Indiana
    1,067
    I have a dent in my 350X tank. The dent isn't very bad. But, i don't have any special tools to get it out. Other then this dent, the tank is in excellent condition. It just needs stripped and repainted. I really hope i don't have to shell out the $200 for a new tank on Ebay. But, I'm sure a body shop would charge that much to fix it too. Since it's such a minor dent, i considered putting body filler in because i'm really good at that, but I don't know if it would hold up under the abuse of riding.
    Any easy ways to fix this? Should i just put a little filler on it and make it look good? I tried to rough up the area so the dent would show better in the picture but i don't know if it is coming out very well.
    Apr 2008
    somerset ma
    1,822
    I would use filler, If your good with it, it should hold up fine.. Mine has alot of filler on it and it's holding up great
    before...
    After...
    NE Indiana
    1,067
    Wow. Yours looks perfect. Good job on that. Yeah, i guess i'll just use some filler if it will hold up. I'm pretty good with that stuff so it should be ok. Other then that one small dent, my tank is flawless, except the 3 coats of paint I have to strip off so i can paint it properly.
    I'm no autobody guy, but you can braise or mig weld some rods on the lowest points of the bad area, heat it up cherry red and pull them out the best you can. Once you have things that hot, they pull out like nothing.....
    Then fill them a bit as the least amount of filler the better!
    NE Indiana
    1,067
    I thought about something like that but i don't have a welder and even if i did, i haven't welded since the mid 90's. I probably couldn't even run a respectable gorilla weld now days.
    If I could find someone to tack a rod on there for me I could give that a try. I'll do some checking around at the local shops. I'm sure i could get someone to tack on a rod for hardly anything money wise.
    Dec 2007
    Indiana
    235
    could always pressurize the tank with air, might pop it out.
    -Phil
    Rides:
    1985 ATC110
    1983 ATC70
    198? ATC200X (sold for $300) (bought back for $50)
    1984 200M
    Past Rides:
    1981 ATC250R (sold for $700)
    2003 Arctic Cat 500 4x4 Automatic (sold for $1000 + a 87 TRX250 Fourtrax)
    1987 TRX250 Fourtrax (sold for $600)
    1978 ATC90 (sold for $75)
    Many Many Other 90 and 110s
    198? Tri Moto 125
    And several other misc, other trikes.
    Air pressurization is the WORST thing you can do! It can explode and kill you....
    Thats why they use water when they build exhausts by hydroforming, if it lets go you get a short burst of water but the pressure immediately drops....
    Nov 2008
    Fryburg PA USA
    83
    Can filler be powder coated over?
    86 ATC 350X
    I do not believe so....
    Thats why I have to fix Goats guard with weld and grind it smooth again....
    Nov 2008
    Fryburg PA USA
    83
    ahh I seee.
    86 ATC 350X
    Feb 2009
    Rome,NY
    1,046
    send it to syko? He does a great job and seems like he dosen't charge alot.... just a sugestion
    Mar 2009
    hazard ky
    25
    could a person put water in it and freeze it that might cause the seams to bust i dont know i have the same problem on my 86 200x
    NE Indiana
    1,067
    Quote Originally Posted by iceman atc View Post
    No. The powder won't stick in that area. If I use filler, i would have to use regular automotive paint etc. That isn't a big problem for me, personally though.
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by mc audio View Post
    Yes, but check it often or it'll be a ball or split
    Rides
    85 ATC350X
    85 ATC200X
