Thread: honda 110 and 125
    louisiana
    1,499
    honda 110 and 125
    will the parts from a 110 engine and a 125 engine interchange,
    Signature pic removed,becuase of no helmet.
    Jun 2006
    Willow, Alaska
    1,337
    What parts specifically? I want to say that they are pretty different engines but Im not 100% on that one.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    louisiana
    1,499
    engine parts.they are both vertical.only few cc's different.i thought maybe they were like the 185 and 200.buddy of mine has a 110 and he needs parts,i have a 125 parts bike.
    Nov 2002
    Kirkville, NY
    3,831
    They share a lot of parts but not as many as the 185/200 engines do. Is the 110 a points (1979-1980) or cdi (1983+) motor?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    check the microfische online, you can get the part numbers and compare them if they're the same then it will work, that's how I check. usually 100% correct. Alot of people use service honda or I always check discounthondaparts.com. Open a window for both machines and start cross referencing. I've had good success with it!
    Good luck
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    Mar 2007
    Texas
    5,045
    the crank and rods are different. the jugs are different heigths, and the bolt patters on the head i beleive is different (larger bore so more spread out).
    internals don't swap basically, but a lot of other stuff does. CDIs will, cams, rockers, guides, electronics and more. I heard there's a guy running around with a 110 that he swapped the bottom end of a 125 for to get the electric start. so he's for an electric starting 110 now. that woud be interesting.
    ________________
    https://www.mikesatvfix.com
