Thread: 86 250r gas in oil
    Mar 2004
    Gettysburg PA
    498
    86 250r gas in oil
    ok well the other day i changed the oil in my 86 250r and saw that it came out real watery, but then i got a big wiff of gasoline. i had noticed before that the compression didnt feel all that great anymore so i firgured the gas got down there becasue of blow by. so i took the head off and inspected the cylinder and did notice it was pretty worn out, like if i take my fingure and put it on the piston i can wiggle the piston inside the cylinder some. like not alot but enough to notice it move and more than enough to let gas get by.
    so my question was how can you tell when its time for a new bore job and piston or just a hone job and rings? thanks
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Dec 2002
    deer park, texas
    2,336
    You will need to put a Mic to see if it is still in spec.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Southern MN
    1,875
    Did you leave the gas petcock on the "ON" position when you parked it? Sometimes if you have a sticky float in the carb and a clogged overflow tube, the gas will just keep flowing and find its way into the crankcase.
    since you have it apart, do a ring end gap measurement, and see what that it comes to. Go from there. Good luck,
    ------ jon
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Mar 2004
    Gettysburg PA
    498
    actualy yeah i have left the gas on and i have come back to it before and noticed some gas had seeped out of the overflow. so that could be it too.
    My Trikes
    1985 250sx
    1986 250r
    May 2007
    Orange County, NY !
    1,673
    Quote Originally Posted by 85 250sx View Post
    Down where? The gas\oil mix pass through the crankcase on every stroke. It's not blowing by the piston and getting in your oil. The oil is transmission fluid, not oil to lubricate the crank bearings, like on a 4 stroke.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    gas CANNOT get into the transmission on a 250r,,,,,, you said watery do you mean thin or wattery... and grey colored like a waterpump seal is leaking,,,,,,,,,,,, GET a manual and do some reading,,,,,,,,,,,
    Mar 2004
    Gettysburg PA
    498
    in watery i ment realy thin and not sticky. and it reaked of gas tho and wasnt realy grey either
    My Trikes
    1985 250sx
    1986 250r
