Results 16 to 30 of 42
Thread: $50.00 BIG RED ... pic is up, AND IT RUNS!!
    Aug 2006
    Arlington, Wa
    1,027
    The engine turns over with the electric starter when the jumpers are hooked straight to the starter. I need to look for the wiring problem so it works correctly. I have the stock carb coming apart to go into cleaner so I can bolt it on.
    I pulled the kehin carb off of it. It is a PWK. I'll measure it so I know what I have then most likely put it on ebay.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Eastern Long Island
    1,688
    That's not the stock seat pan. 85-87 had plastic pans so it should be easy to find a good seat.
    Lots O Trikes!!!!!
    Aug 2006
    Arlington, Wa
    1,027
    Quote Originally Posted by 200xman View Post
    SWEET! that is great news right there! Thank you much for that info.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    gizmo_22's Avatar
    gizmo_22 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2006
    Bathurst NB Canada
    305
    Great score on that trike man! Looks like its cleaning up nicely. Keep at er!
    Aug 2006
    Arlington, Wa
    1,027
    I'm going to just work on cleaning the engine (oven cleaner) and cleaning the carb in the morning. I want to hear it run before I buy the one way clutch.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Eastern Long Island
    1,688
    Doesn't look bad for $50. You need to get some 25" tires on there, those 22"s look tiny! Be sure to check the rear end oil as the 85's were known to get water in there from a poorly sealed driveshaft boot.
    Lots O Trikes!!!!!
    Aug 2006
    Arlington, Wa
    1,027
    they are 25", and they have 3 pounds of air in them. They are Duros so I bet the rollout is a bit small.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    NE Arkansas
    2,344
    nice score!
    My Rags
    Aug 2006
    Arlington, Wa
    1,027
    carb kit is in route. She should run by next weekend
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    I got one free once. It needed bearings in the rear axle. I got it running and rode it a little. My grandfathers BigRed that is in good shape, needed a electric starter and my bigred became the donor bike for a couple of years then we pulled the motor out of it and the rear axle off of it. and we put the motor in a metal 55 gallon drum with a lid to keep it out of the weather and we hauled the frame for scrap. The motor was in that metal drum for about two years and apparently the drum leaked and filled with enough water to get into the motor and froze it solid and it was a real good running motor. on the next scrap run, the motor went on it. I still have some of the rear axle parts left of it though.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    maggies, that looks like a 250r carb. know the diameter of the boot side?
    Nothing to ride... for now
    Aug 2006
    Arlington, Wa
    1,027
    It runs!!!!
    I took my 350X carb off the shelf and bottle fed it fuel, and it started and sipped nearly a cup of fuel. I shut it down when I noticed fluid dripping down onto the spark plug. It burned off right away so it isn't oil. I'll run it again tommorrow and see if it just might have been some residual water from when I washed it.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Aug 2006
    Arlington, Wa
    1,027
    according to a website I just found, it is going to be a 35 mm PWK based off of the measurements and model number.
    http://www.motorcyclecarbs.com/keihi...cfm#Dimensions
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Aug 2006
    Arlington, Wa
    1,027
    I need some help!! does anyone have, or are you willing to take a picture of the rubber grommet that hold the spare fuses and wire connectors under the headlamp? I'm trying a few different ways to route the wires, and I'm have some difficulty getting it right.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
  15. #30
    Eastern Long Island
    1,688
    Quote Originally Posted by maggiesboy View Post
    Good luck !!!!! There's not much wiggle room in there. I'll post a pic of mine in the morning. I can't swear that the routing is OEM but the cover fits on so I guess that's what counts.
    Lots O Trikes!!!!!
