Results 1 to 8 of 8
Thread: 350x clutch problem
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    Question 350x clutch problem
    when i let out on my clutch it makes this squealing sound does it need new fibers and steels?
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    Squeeling has nothing to do with slipping..... Who knows what you have going on in there?
    Warm up the bike, roll down to about 10MPH in 1st gear, pull in the clutch and upshift to 3rd or 4th, get your revs up and dump the clutch.
    Does it rev high, slowly descending until it finally grabs (slipping clutch) or does it bog right down and take awhile to get up to speed? (good clutch)
    atcrider1's Avatar
    Mar 2009
    Montrose MI
    400
    thanks for the reply, the clutch doesn't slip it it just screeches when i let out on it?
    -Uller God
    Terryville,CT
    1,616
    Check your oil sounds like friction to me! or loose clutch basket maybe ,all just speculation!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    atcrider1's Avatar
    Mar 2009
    Montrose MI
    400
    alright thanks
    -Uller God
    If anything is wrong with the steel or friction plates, it will slip.
    Odd noises could be a clutch spring bolt that backed out, or a clutch that wasn't assembled correctly. The throwout bearing could be bad too, does the noise change if your idling and pull the clutch in and out during different RPM's??
    For that matter, if any of stuff under the right case has been messed with, it could be anything....
    PA
    3,515
    my buddys 350x always made this noise when pulling out. it's nothing to get to worried about, his is still running after 10 years.
    WWW.HREATV.COM
    Apr 2006
    Crestview, Florida
    2,429
    Sounds like the throw-out bearing to me. Pull the right side cover off and see whats up.
    Rides
    85 ATC350X
    85 ATC200X
