Results 1 to 15 of 46
Thread: 85 tecate help
    Mar 2009
    hazard ky
    25
    85 tecate help
    i just bought a 85 tecate in fair shape for $270 it runs but if dose not have the power it should have i dont think the power bands is kicking in it has extended swing arm and axle extenders on it i think that is was raced once flat track it sits low to the ground but any help would be great thanks
    NE Indiana
    1,067
    A little more info would be helpful. Is the pipe dented up? Anything else that could cause it that you might be able to mention?
    Sometimes you have to grease the power bands. After a while the grease dries up.
    Mar 2009
    hazard ky
    25
    the pipe has a a dint and a crack about 5 inches after it comes out of the motor when you wind it out in high rpm it cuts out a little
    NE Indiana
    1,067
    Quote Originally Posted by mc audio View Post
    Depends on how bad the dent in the pipe is. You can find good pipes on Ebay cheap. I would go with a different pipe and then clean the carb and get it jetted. That is the first things i would do.
    Mar 2009
    hazard ky
    25
    i ordered a new set of reed valves for it hope it helps it
    I'd get new power bands while you're in there.
    Mar 2009
    hazard ky
    25
    can i weld the tear in the pipe
    Mar 2009
    hazard ky
    25
    i had a 85 a long time ago it was a beast it ran a lot better than this one but it was down biggest part of the time this one seems to be more reliable i will post some pics up tomorrow
    Apr 2004
    Brigham, Québec, Canada
    1,529
    IIIIIIIIIIIIII.............................IIIIIII IIIIIIIIIIIIIIII ....III FUIEYDJIHJIGHF
    Here is a bunch of letters and characters to add to your messages.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Mar 2009
    hazard ky
    25
    Sorry about the typing.
    Mar 2009
    hazard ky
    25
    hear is a pic added
    NE Indiana
    1,067
    Well, I must ask, where is the radiator? Is that thing on the front a rigged up radiator?
    Quote Originally Posted by jeswinehart View Post
    Don't mind the hecklers, they will find something else to do after awhile.
    john
    Sorry John, I couldn't resist...
    NE Indiana
    1,067
    Also, when you say that the pipe has a tear, is it tore or dented? If you could get better pics of the pipe that could help. And like John said, if you can get a compression check on it. I am wondering about the radiator though. It that box that's mounted on the front a radiator? Is it hooked up to the hoses and stuff? If there is no radiator hooked up, is could be running too hot and that could cause problems too.
    Could you maybe get a few more close pictures?
