Results 16 to 30 of 46
Thread: 85 tecate help
    Mar 2009
    hazard ky
    25
    I think it has a radiator off a kx bike yea it is rigged.What should the compression be on it .
    Mar 2009
    hazard ky
    25
    I fixed the pipe today puled the dent out and welded the tear. It did not help any.I also took the carb off and went through it was all in good shape.
    krazykane is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    morrisville pa
    229
    what should a 84 t3 be jetted to
    NE Indiana
    1,067
    Quote Originally Posted by mc audio View Post
    Well, it is possible that the radiator is not cooling it properly. That is a much smaller radiator than stock. From the picture it looks like the bottom of the pipe is dented pretty bad. It might just be the picture though.
    If that pipe is dented up pretty good, you will definately lose a good amount of power. Yes, pipes are that touchy. Like I said earlier, you should go to ebay and buy a pipe and now, I would get a radiator too. they are very cheap on ebay in good shape. Then i would take your carb apart and clean it really good with carb and choke cleaner.
    Last thing to do is go to the local hardeware, or Advanced Auto / Auto Zone and buy some Plastidip, tool dip. It is the coating they use to recoat the handles on pliers and stuff. It will cost $15 or less. While your carb is off, coat the intake boot with 2 good coats of the plastidip. Let the first coat dry for an hour or two then coat it again. Let it dry for a day then.
    If you do all that, i bet you'll bring her back to life. As far as compression, I'm not sure personally about how much it should have. i'm sure one of the other guys will fill you in on that.
    NE Indiana
    1,067
    well, if you pulled out the only dent and welded up any holes/tears, we can basically rule that out. Try to get a compression check and post it so some of these guys can help with that. Plus, try the radiator and plastidip for the intake, Like in my last post.
    Quote Originally Posted by krazykane
    http://www.3wheelerworldforums.com/s...ad.php?t=55086
    Dec 2002
    Spruce Pine, Alabama
    1,263
    I don't know if it was ever raced, but it was built from a bare frame with the intention of racing. I just never got to finish it.
    Here's(below your pic) what it looked like when I sold it in 2007 and delivered it to Kentucky......as a rolling chassis and a LOT of parts.
    i just bought a 85 tecate in fair shape for $270 it runs but if dose not have the power it should have i dont think the power bands is kicking in it has extended swing arm and axle extenders on it i think that is was raced once flat track it sits low to the ground but any help would be great thanks
    '84 ATC70.....my 8-y.o. son's ride
    Mar 2009
    hazard ky
    25
    That's it has 03 on the fenders
    Dec 2002
    1,263
    I had a local welding shop extend the factory swingarm 2-inches, I spaced the gas tank back and cut the steering stops down a bit, and I took the forks apart and switched the top-out springs with the top spring like the Jimmy White manual called for when setting up for a smooth flattrack(lowered 5+ inches from stock). I hadn't lowered the rear yet when I had it. I painted the hubs and spacers with the same paint that the plastic had been painted with at an auto-body shop before I got it.
    I bought the rear wheels new with a set of Duro-HF-245's, and put a narrow (new Kenda front Max)front tire on it. The radiator isn't my doing, though.
    I sold it to a guy named Rick that I met through Eric250R here on the boards and met him in KY along I-65 in June of '07.
    I've still got pics of the whole deal from painted frame to the classified pics I posted here back then. It spent it's pre-Kentucky life in North Alabama.
    NE Indiana
    1,067
    This certainly helps that one of the previous owners(DixiePlowBoy) is here to give some info on some of the history of the trike. Definitely an advantage.
    Dec 2002
    1,263
    Sad thing is, I never got to ride it. I've always wondered if it handled like I expected it to( a sideways-sliding dream). Now that someone has ridden it, maybe I'll finally know if I did any good or not...lol.
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Wow dixie. Great info for mc. I only ever talked with 1 person on who owned a bike of mine. And it helps out ALOT. And like jeswinehart said. There are alot of dead beats. Grease the power band. What a tool.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Mar 2009
    hazard ky
    25
    This bike is a sliding machine very stable. I am going out to do a compression test on it right now
    NE Indiana
    1,067
    Quote Originally Posted by Tecate250 View Post
    I thought that was pretty funny and I'm sure mc audio knew it was just joking around as well. I like to joke a lot as well but I've noticed around here a lot of people get offended very easily. I don't understand why. I try my best to put a smiley face next to my jokes to make sure people know that I'm only kidding and mean no offense but we should be able to kid around and have fun with each other without scrutiny, right? We are all here because we love trikes but we also want to inject a little fun as well.
    Nov 2002
    1,838
    I too feel the same. BUT not all of us know every term. What if he was a newb? I can see him now searching the web on how to adjust the power valves. He came in here looking for answers. If you joke around make it good and clear. Since the old days when we had fight club where most of the joking around went. But alot more bull happened in there. I always respected all of peoples views and oppinions. How do you know I too was kidding around?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  15. #30
    NE Indiana
    1,067
    I agree. You do have a good point.
