Results 1 to 15 of 16
Thread: 200x oil cooler pics
    Dec 2007
    Quebec,Canada
    1,014
    3 week ago I bought this 200x,completly destroyed,everything had a problem.This 200x was mine 7 year ago,I sold it to a friend,he finally sold it to another people that ran it for 3 week and blow the cam....was sitting outdoor under a tree for 5 years.I bought it for 150$ and will never sell it.I have completly restored it (Need rear fender and tank paint).I add a supertrapp exhaust,xr200 cam and carb,a good porting to the exhaust port and this oil cooler.And the DIFFERENCE between stock and all this mods,BIG difference,a lot more power.oil cooler is from a cb900c,with this setup I can install the stock headlight and I will built a custom headlight guard to fit with the cooler,
    Attached Thumbnails Attached Thumbnails 200x 001.jpg   200x 002.jpg   200x 003.jpg   200x 004.jpg   200x 005.jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Feb 2009
    Rome,NY
    1,046
    Wow looks really nice. I am redoing a 85 200x myself and thinking about the xr setup with a cooler from something similar. Did you consider running the return line to the head (above cam) ? Also where did you get that cool billet looking spacer for the carb?
    braunz200x's Avatar
    braunz200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Toronto
    158
    Is it ok to use bolts instead of studs on the head pipe?
    Dec 2007
    Quebec,Canada
    1,014
    Bolt or stud make no difference,but always use antiseize on thoses bolts.
    I don't think another oil line for the cam is necessary,if you have a good oil pump,use good oil and make sure all oil gallery are clean on rebuilt,cam have enought oil with the factory setup.If you paypass more oil to help the cam you will probably kill your crankshaft cause the gallery you drill for the oil cooler isn't a main,it's the crankshaft lubrication only.
    The spacer for the carb is homemade in a piece of aluminium
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Dec 2005
    Wisconsin
    1,141
    Good looking trike man! Looks like it should be a runner. Good to hear the porting, carb, and cam made a big difference. I can't wait to get mine together!
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Nice job on the oil cooler!!!!!!!!!!!!!
    Whole trike's looking good....
    BRAUNZ:
    They use studs on the exhaust because they are intended to stay in the head. Some stock studs have distorted threads on the side that threads in the head, intentionally so that they won't back out.
    There is also a crush factor of the sealing ring. If your bolts are too short - stripped head $$$$ If your bolts are too long - stripped head $$$$ and or an exhaust that doesn't fully tighten.
    I take out the stock studs, chase the threads and use stainless steel studs so I can get them apart at a future date!
    Feb 2009
    Rome,NY
    1,046
    ok I was thinking that the crank splashed around in the sump and that galley you tap into was for the top end....
    Feb 2008
    Pennsylvania
    2,305
    My buddy has a bottom end for a 85 200x that has already been set-up for an oil cooler. Does it really help the 200x? Been thinking of building one up.
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    Feb 2009
    Rome,NY
    1,046
    Quote Originally Posted by oldtime3wheeler View Post
    can't hurt ... extra oil capacity and cooler oil = longer happier engine life
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    I like the spacer you made for the carb to line it up correctly. I've been thinking about an XR200 carb for a while but never did it because people say that the carb boot that connects to the head doesn't allow for correct alignment with the airbox boot. Since I don't know how to machine stuff, and don't know anyone that does, it looks like it'll never happen.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Apr 2007
    Springfield, PA
    889
    Quote Originally Posted by Solid Snake View Post
    ...I've been thinking about an XR200 carb for a while but never did it because people say that the carb boot that connects to the head doesn't allow for correct alignment with the airbox boot...
    dont want to hijack the thread, but certain year XR200 carb boots should work on the 200x. if i remember correctly i believe their 2mm bigger also. the stock 200x boot should also work with a XR200 carb. check out these threads:
    http://3wheelerworldforums.com/showthread.php?t=95158
    http://3wheelerworldforums.com/showthread.php?t=72846
    http://3wheelerworldforums.com/showthread.php?t=75936
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    heres mine useing a 350x cooler..
    Apr 2006
    SE CA Dez in the sandbox
    892
    Oh, I like that install. Sure would be more efficient if the air would flow thrugh the fins rather than past them. Did you think about mounting the cooler up on the forks, as in the earlier post??
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    Baltimore, MD
    6,088
    I have an old nos aftermarket oil cooler kit that basically mounts in the same place under the rear fenders, but it has a fiberglass scoop that forces the air across the cooler. Here is a few pics of the kit.
    Attached Thumbnails Attached Thumbnails tmpphpMVK6M2.jpg   tmpphpkZ5B0E.jpg   tmpphpBVofNc.jpg   tmpphpwsbORs.jpg   tmpphpxOn8Qv.jpg   tmpphpjoxCVj.jpg
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Visalia, CA
    720
    Hey veal wana sell that oil cooler?
