Thread: All Balls kits ???
    Apr 2008
    somerset ma
    1,822
    Question All Balls kits ???
    does anybody here run them here for the 350X?, if so what are the pros-cons of setting them up? such as do you need spacers and such for both tripple trees?
    any input would be greately appreciated
    Thanks
    Tank
    :edit: I forgot to mention, these are for the steering stem
    Hopefully someone will let you know if it had any issues...
    With the 86 200X it didn't want the washer, but it didn't seem right without it either.
    My trick is to remove all the OEM parts and stack them up. Then you can measure top and bottom and match that to the Allballs kit. Thats how I arrived at needing a .040 washer so the kit would be the same height as the OEM stuff.....
    fire1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    Roanoke,Virginia
    404
    i just used them on my 350x build and no problems so far
    Jan 2005
    RI
    2,530
    one of the first things i did was put a set in my old 350 after the steering locked and made me hit a swingset...
    they went in really easy and didnt need any mods. They go on every trike i have now
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Bump for seabass!
