Over spring break I got the exhaust done for the 85 200x project. I would have bought a head pipe alone from cobra but they aren't making them again until July.. I need mine now. So I ordered a 1-3/8" J bend from Jegs for 14 dollars and a chunk of 1-3/8" tube from Discount Steel for 20 dollars. The rest was my time. I kinda guessed on the bend radius as I am here at college and the wheeler is at home, luck would have it the radius worked out perfect and is exactly the same as the stock bend head pipe. From there I began cutting, fitting, welding and refitting. I have some time in this as I wanted it done right and done once, it took me a whole day in the garage working. As you can see in the pic's I am using the stock muffler with bigger pipe going back all the way from the head pipe into the muffler. Reason for the stock muffler is I trail ride this thing it needs to be somewhat legit so I don't get tickets and piss people off. The rear baffle is removed and I did a little work on the inside, it should be a bit louder and flow better but not cause problems. Oh yeah the other thing this needs to keep the sleeper look, and I think the stock muffler achieves that for me. After everything was fit I took a bunch of time filling welds and smoothing everything out so it looks almost seamless, I also added the stock heat shield for the finished look. I will post pic's of that when I get home next time. Over Easter break I am going to go home to finish the pipe, I need to lightly sand blast it and spray on the ceramic coating and bake it. I bought the chrome ceramic stuff you have to bake for an hr. at 500 deg. If it turns out like it should this thing should look real sweet. I'm going to spray the pipe and muffler.
