Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: Here's how you build a 200x exhaust...
    Dec 2005
    Wisconsin
    1,141
    Idk... What I really need is a good intake that is stock so I can get the angles exactly the same. Mine is a bit off because I chopped up the original not knowing it was rubber molded. If I could get a stock one to make a few good ones out of it wouldn't be to bad and they would be exact. Mine turned out good for guessing the angles and length lol. What do you guy's think a fair price would be on these things?
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Mar 2007
    Texas
    5,045
    i can send you a stock intake to mock up with. I'm not using my 200x right now. if you give me a good deal on one of them u made, I'll send it to ya.
    one thing that may help ya, on the carb side of the itnake, make the hole a slight bit larger, jsut a hair so there's no lip from the carb touching the intake hole and then on the port side do the same except make the end jsut a hair smaller than the intake port so there's no lip it hits when flowing. this helps flow due to no lip or dip in the flow.
    ________________
    https://www.mikesatvfix.com
    Dec 2005
    Wisconsin
    1,141
    Yeah that would work I guess. I don't have a clue what these things are worth and I have mine done so if a bunch of people want these things tell me what they are worth to ya, and I will see if they are worth my time making them.
    Oscar when I made mine I aligned everything to match the new carb. Everything is matched with the die grinder in the end and finished with 80 grit sand paper. You don't want a smooth intake wall, the 80 grit gives enough turbulence to keep the gas from falling out of atomization and sticking to the walls.
    1985 Honda 200x...
    gizmo_22's Avatar
    gizmo_22 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2006
    Bathurst NB Canada
    305
    well i had to buy a new one from the stealership here and it was like 16$ cdn if i remember right. Give em a call and price one, their not overly expensive.
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by gizmo_22 View Post
    New intake and billet intake that fits a larger 30mm carb are two different things. Machine time costs money, I don't crank handles for free.....
    1985 Honda 200x...
    gizmo_22's Avatar
    Sep 2006
    Bathurst NB Canada
    305
    ah didn't notice it was for a larger carb, my bad :P
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    This is a good thread, I would have never thought to look at pre-bent tubing to fab an exhaust. Nice work. I'm gonna move it to the Mad Scientists lair.
    Dec 2005
    Wisconsin
    1,141
    Haha Thanks Billy I feel Honored to contribute to the Mad Scientists layer.
    Another tip with the pre-bent stuff some of the different companies measure bend radius's differently. Some measure to inside of pipe, some to middle. Jeg's shows a lot of the measurements, and if it's not listed give them a call.
    1985 Honda 200x...
    Feb 2009
    michigan
    2,387
    200x pipe
    nice job,you may need to go up one on your carb jet.i think the diameter is good on your pipe,you should be fine.looks the same as aftermarket pipes
    1985 ATC 250R
    . Team Red Trike
    Dec 2005
    Wisconsin
    1,141
    There's the final product after it has been ceramic coated. It turned out very nice, and sounds good too.
    After all the engine mods I wet from a 115 jet to a 135 jet. She runs good.
    1985 Honda 200x...
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Very nice X you have there! Maybe I should try something like you did, but for my 225dx.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Jun 2009
    oglesby IL
    38
    Man that is nice looking. Good job on the fab work it looks great!
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    What is that spray-and bake coating called?
