Results 1 to 10 of 10
Thread: Just wanted to make sure
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    Finally got the 200es and 250es out on the road together, I just wanted to know that why the 200es is so much faster (top end) than the 250es, tires are pretty much the same size
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    Tionesta, PA
    5,747
    How much faster is "so much faster" - my guess is that your 250ES is worn out. they should top out at about the same speed.
    New Orleans, LA
    201
    nah, like 15 mph difference, the 250es just seemed wound out, like a gearing issure, top end is fresh!, on both bikes
    pudge is offline At The Back Of The Pack Arm chair racerFirst time rider
    CT
    159
    i had a 250es and my buddy has a 200es, they were just about the exact same speed, maybe the 20 was even a little quicker because is shifted better
    Tionesta, PA
    5,747
    What sized tires are on both machines? They should both have 25" rear tires. Tire size makes a big difference in a machine that you can not change sprocket size on.
    CT
    159
    i just notice you wrote tires are "pretty much the same size" there will be a huge difference from 22 inch to 25 inch tires are far as how fast they will go
    New Orleans, LA
    201
    they are both 25's, the 200es has new bear claws, 250es has some wooly boogers, not bald, but not brand new!
    Apr 2006
    Crestview, Florida
    2,429
    make sure you have them both set in high range
    Rides
    85 ATC350X
    85 ATC200X
    Tionesta, PA
    5,747
    measure the tire heights - Are they alot different in height?
    Oct 2008
    NB, Canada
    852
    I know the 250es' are heavier, 405 lbs I think, and the 200es' are 375 lbs.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
